need wiring diagram
Old Jan 8, 2007 | 07:09 AM
sethwas's Avatar
need wiring diagram
Anyone have the haynes for an '02 max. I need to know for the headlights (xenon) which colors are which feature. I.e. blue is low beam, black is ground, etc. for the left and right sides. My turn signalls work, and the high beams, but not the lows and I think I have something switched. A scan of the book, or just telling me red which white stripe is low will suffice.
Thanks,
Seth
P.S. The FSM doesn't show colors for the actual headlight wires, just the harness. So if someone has an '02 max with the factory HID (like mine) you could just tell me the high beam left wire connects to the red wire, and the HID middle wire connects to the green one, or whichever color is which. That would be easiest. And you could just pop your hood and look instead of futzing with a manual.
P.P.S. For those who want to know why I'm doing this, I'm putting the HID's back on the car. They were stolen twice so I just put the halogens on, but now that I'm selling the car I need to put them back on.
Old Jan 8, 2007 | 09:30 AM
sethwas's Avatar
Ha,
Silly me, I have the wire colors, I just need to know the order they go on the bulbs as the bulb wire and the harness wire are one and the same.
Can anyone look under their hood and tell me?
Thanks,
Seth
P.S. the reason I ask is because the OEM HID repair kit comes with only yellow wire.
Old Jan 8, 2007 | 01:52 PM
KabirUTA13's Avatar
IN IRAQ MAXIMA.ORG-ING :)
best thing u can tell u is using a test light... try turning ur high beam switch on and see if ur low beam come on...?
Old Jan 8, 2007 | 04:01 PM
sethwas's Avatar
It's not that simple.
The HID's use 3 wires and work together with the parking lamps in series. So you need to have 3 wires connected to try them. I can get the HID's up but not the parking lamps and vice versa.
I ran out of daylight before I could continue.
According to the FSM the
left side parking lamp uses a red/yellow wire
the left side hid uses an "L" colored wire
and the left side high beam uses "P"
black/yellow is the HID ground
"L"/white is the high ground
the right side parking lamp is red/yellow on high
the right side hid is red/"L"
the right side high is orange/blue
the right side hid ground is black yellow
and the right side high ground is LG
If someone could just tell me if the 'left side hid low' is the middle wire, left wire or right wire when viewing from above that would be helpful.
Seth W.
Old Jan 9, 2007 | 04:14 PM
sethwas's Avatar
OK,
Thanks for the help. Here is the solution.
The black wire is the ground and is the middle of the three wires in the HID plug.
The red/yellow is the parking lamp and if you are facing down with the plug in its socket, it is the right side.
The remaining wire, the green or blue one is the HID and that is the left side.
Seth
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
