axis hiro
Old Jan 9, 2007 | 06:21 AM
absoundlab
axis hiro
would 19x8.5 front and 19x9.5 rear with a 20mm offset fit a 5th gen
Old Jan 9, 2007 | 06:29 AM
MaximaGT-R's Avatar
I'm a Happy Man!
i dont think it will this is a guy here from florida whose got 19x10 in the rear but its got 35mm offset and he said that was a tight but perfect fit.
here check it out
http://forums.maxima.org/showthread.php?t=505253
Old Jan 9, 2007 | 08:19 PM
irish44j's Avatar
retired moderator
20 offset on an 8.5" wheel will stick out about 3/4" past the wheel wells in the front.
Go with a 8" front with 30 offset for a flush look. If you must have staggered in the back (why, why, why?) go with a 9" with 30 offset for flush (you might rub a bit though if you're low).
Old Jan 9, 2007 | 08:25 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Hiro's are prone to cracking....just FYI.
Old Jan 9, 2007 | 08:35 PM
irish44j's Avatar
retired moderator
Tim....time to change your avatar, methinks
Old Jan 9, 2007 | 08:49 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Changed.....
Old Jan 10, 2007 | 08:36 AM
sweetjackal82's Avatar
I have +33 offset front and rear. Fronts are almost PERFECT. Rears could come out a bit.
BUT... If you want the staggared look without the complications... get the Axis wheels with the "maxis lip"
big h
Jun 19, 2003 04:40 AM
samiam
May 31, 2003 10:39 PM
neverdat
Sep 28, 2002 09:24 PM
VQracer
Nov 1, 2001 06:08 AM
