P0420 linked to MAF?
Old Jan 12, 2007 | 01:23 PM
steelymatt's Avatar
Hi,
I've had a recurring P0420 code for a bad catalytic converter. The cat seems like the obvious solution. The ECU has the latest software. Is there any chance the bad reading at the cat is actually just a result of a bad MAF sensor upstream?
Thanks,
Matt
Old Jan 12, 2007 | 02:50 PM
P. Samson's Avatar
No, usually associated with intake air leaks or injector problems. What mods have you got?
Old Jan 12, 2007 | 03:06 PM
steelymatt's Avatar
No mods on the intake, all stock except for K+N air filter.
Old Jan 12, 2007 | 03:55 PM
P. Samson's Avatar
Performance OK? Any surging/hunting, throttle hanging (if a MT), idle stable and around 700 when warm?
Old Jan 12, 2007 | 04:17 PM
steelymatt's Avatar
Yes to all.
The car is a little slower than it used to but that's understandable for a car with 87K miles. I was planning to replace the MAF sensor just for the hell of it, and I was hoping it might take care of the P0420 problem.
Old Jan 12, 2007 | 06:44 PM
P. Samson's Avatar
I would get to a dealer on this. Your Fed. emissions warranty may cover it AND there is a TSB 00070 (NTB 00-070b) for a P0420 DTC that may apply to your car if it hasn't already been accomplished. FIRST.......get that K&N air filter replaced with any non-oiled one. FYI, the ECM and MAF/sensor element/ASSEMBLY have to be "matched". This is not an option, contrary to some.
Old Jan 12, 2007 | 06:46 PM
CoolMax's Avatar
is invisible
http://forums.maxima.org/showthread.php?t=289375
TallTom
57
Oct 14, 2025 05:16 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
