some problems im coming across
Old Jan 22, 2007 | 05:59 PM
jawwaad05's Avatar
this is all for a 2k 5spd
1.)i keep getting cylinder 2 misfire and i thought the studder in low rpms was because of the fuel cut issue also my CEL blinks sometimes usually whn i go over about 3200 and then stops and does it again ... wat do i need to get raplaced?
i replaces the sparkplugs
2.) whn im accelerating it feels like the car doesnt have much power on higher rpms... like ill take it close to about 7000rpm change to 2nd and itll have a boost of power but after like 3000rpm on each gear theres alot less power... is this normal on 2000 5spd
3.) if i start in the morning and have it in neutral.. and rev the car its not a smooth rev its more like revnoise.... revnoise...... revnoise... kinda studders... and then if i take it for a drive **** jerks like crazy ! if i warm it up its decent not as bad .... im assuming its the fuel cut problem em i right ? it does have a lil studdering in 1st and 2nd gear at times (which i absolutely hate looks like i cant drive stick!!)
4.) also whn im in neutral stopped at a light or just chillin the car shakes alot!!
any one know wat these problems could be ?!
Old Jan 22, 2007 | 06:35 PM
kbjy11's Avatar
99.9% sure it's ignition coils
you're are describing all the symptoms..
replace cyl 2's coil, and see if that helps.
Old Jan 22, 2007 | 06:39 PM
00MaxSE's Avatar
Pointy Elbows
That is definately the problem. Been there, done that.
/thread
Old Jan 23, 2007 | 12:37 AM
jawwaad05's Avatar
so all those problems are just cuz of coil ignitions? thts it
Old Jan 23, 2007 | 01:05 AM
AceofSpds's Avatar
wat
Yup just 1 ignition coil, go to orielly auto parts and buy one, i think its 5 dollars more there than what you pay for the cheapest oem nisssan coil online, but the orielly coil has a lifetime warranty
Old Jan 23, 2007 | 04:23 AM
00MaxSE's Avatar
Pointy Elbows
I would check to make sure you have the grey dot coils in already. If not, you might as well replace them all because they will go eventually.
Lakersallday24
Nov 7, 2024 07:31 PM
tsi6001
Oct 3, 2022 10:23 PM
Lakersallday24
Jun 16, 2019 01:35 AM
homeyclaus
Sep 3, 2015 06:15 PM
mrgooch
Sep 1, 2015 04:10 PM
