Going to Nissan to reset ECU for new MAF...
Old Feb 6, 2007 | 02:47 PM
The Legend's Avatar
My question is, while I'm there ,what else can I have them adjust with the consult II besides timing advance?
Old Feb 6, 2007 | 02:49 PM
SoonerFan's Avatar
Cletus
do you mean reflash?
a reset, you can do yourself by disconnecting the battery overnight.
Old Feb 6, 2007 | 02:54 PM
The Legend's Avatar
yes reflash
Old Feb 6, 2007 | 02:55 PM
SoonerFan's Avatar
Cletus
Originally Posted by The Legend
yes reflash
ok cool...just making sure you knew the difference.
to answer the question, timing advance is the only thing ive heard people do.
Old Feb 6, 2007 | 02:57 PM
The Legend's Avatar
ok thanks, thats all i've heard too
Old Feb 6, 2007 | 04:45 PM
wyche89's Avatar
hey, i had a question.. this ecu reflash procedure.. do they really do what they say they do? or do they just turn off the check engine light, like you can do with an OBD.. because it seems awfully convenient that the process supposedly takes an hour so they can charge you the full hourly service rate
Old Feb 6, 2007 | 04:50 PM
SoonerFan's Avatar
Cletus
they actually reflash the ECU to change the software to fix the problem (its like a firmware update). its a file that is saved to the ECU. an hour of labor is normal
Old Feb 6, 2007 | 06:24 PM
nismopc's Avatar
Most to all dealers will not charge anything less than 1 hour of labor even if it takes them only 15 mins.
Old Feb 6, 2007 | 10:39 PM
S00NR1's Avatar
OU > *
Got the new MAF, but never got the reflash done.....no probs here.
Old Feb 7, 2007 | 07:25 AM
nismopc's Avatar
On the 5.5gens there is a TSB out for hesitation between 2500-3000rpm. If you were not experiencing this before you replaced your MAF, it is probable that you have no need for a ECU reflash.
I was experiencing this hesitation pre and post MAF replacement. After the ECU reflash, it has completely gone away.
Old Feb 7, 2007 | 08:51 AM
OhOhMax's Avatar
Is this a must when replacing a MAF? Even if you have no SES?
Old Feb 7, 2007 | 09:38 AM
mist max2000's Avatar
didnt reflash mine..no prob at all here (and thats goin back to last summer ish)
Old Feb 9, 2007 | 07:27 AM
NisTech's Avatar
all you can do is timing advance, clear any codes if you have an engine light, unless you have a knock sensor witch won't set a light. Basicly nothing else.
Old Feb 9, 2007 | 09:05 AM
ShIft_uR FacE's Avatar
question...had my ecu changed. does this mean i need the timing advanced again? any way to verify?
Old Feb 9, 2007 | 09:08 AM
nismopc's Avatar
Changed? What do you mean?
If you swapped in a different ECU, then yes.
If you had the ECU reflashed, then yes, most likely all previous settings were wiped out.
Old Feb 9, 2007 | 09:22 AM
A new one was swapped in as the old one was "dying" as told by the dealership. So my answer is yes either way. Thanx.
Old Feb 9, 2007 | 01:58 PM
SoonerFan's Avatar
Cletus
when you advance your timing...its done in the ECU.
Old Feb 10, 2007 | 07:06 AM
thought so just making sure. dont get dizzy spinning around so much.
Old Feb 10, 2007 | 07:33 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
you can also bump the idle target if you have an udp that is spinning too slowly.
Old Feb 10, 2007 | 08:18 AM
00maxipad's Avatar
so when you advance the timing what does it actually do performance wise and how much you advance it?
Old Feb 10, 2007 | 10:44 AM
The Legend's Avatar
ok just got back from the dealer. so how can i make sure they did what they said they would do? could i just take it by autozone and have them check?
Old Feb 10, 2007 | 12:41 PM
SoonerFan's Avatar
Cletus
17 degrees
improves throttle response.
Old Feb 10, 2007 | 07:09 PM
NisTech's Avatar
Honestly i would never have an UDP installed on my vehicle.
And why would i try to compensat for an UDP by raising idle RPM? Burn more gas? We do have the torque we need unlike hondas.
UDP slowes down your accessories. Not ideal in my books...
Old Feb 10, 2007 | 10:16 PM
oldskooljdm's Avatar
i have the hesitation problem that nismopc was talking about between 2500 and 3000rpm. it drives me crazy. its like my car just falls on its face for a second then takes off. So when you go to the dealership for the reflash can you just tell them to advance the timing 17 degrees and they'll do it?
Old Feb 11, 2007 | 09:23 AM
The Legend's Avatar
any suggestions?
Old Feb 12, 2007 | 05:14 PM
NisTech's Avatar
ASK for a printout before you do it. That way when it's done you'll have your printout.
ballerchris510
Sep 10, 2015 09:35 PM
mix master
Sep 4, 2015 05:50 PM
coasterswim
Sep 2, 2015 07:43 AM
