K&N Intake for 2k2 recommend???
Old 02-07-2007, 12:27 AM
Topher3284's Avatar
Just wondering if anyone recommends this type of intake. Does it make a good difference? What are the advantages and disadvantages? Just looking for some advice.
Topher3284 is offline
Old 02-07-2007, 12:41 AM
Go BUCKS!!!
SEmy2K2go's Avatar
Are you asking about a K&N filter, because as far as I know, K&N does not make an intake for the Maxima?
Please consult the FAQ's for any information on intakes as well as the MANY 100's of threads on intakes listed in this section such as this recent one.
SEmy2K2go is offline
Old 02-07-2007, 12:50 AM
Topher3284's Avatar
Oops, i mean air filter. I do believe they make those right? (Man, Shouldn't do this after a night out)
Old 02-07-2007, 12:52 AM
Go BUCKS!!!
SEmy2K2go's Avatar
Yeah, there is a K&N drop-in filter for our cars. K&N is a long proven product that many people use in their cars (myself included) and they work well as long as you keep up on the regular maintenance of properly oiling them when needed. You won't see any sort of huge gains in terms or MPG or HP #'s, but the convenience of just cleaning, re-oiling, and reinstalling is what draws many people to buy the K&N product.
Old 02-07-2007, 04:54 AM
I'm a Happy Man!
MaximaGT-R's Avatar
For just an air filter the K&N is recommended, but just like SEmy2K2go said "You won't see any sort of huge gains in terms or MPG or HP #'s" so if you a seeking performance i would recommend injen CAI. there is a couple of different intakes out there but i've had injen on my car for almost two years not and i luv the sound and the power. Try doing a search of sound clips that will help you out alot.
MaximaGT-R is offline
Old 02-08-2007, 01:01 AM
maxfive-O's Avatar
Or you can make your own OSCAI - Cold air intake with the stock airbox.
http://www.cardomain.com/ride/821083
Nice quiet intake noise with good response.
I've driven in deep water with no problems. The slit on the upper connector will open before the weight of the water climbs up the tube, in theory.
Good luck
maxfive-O is offline
Old 02-08-2007, 03:31 AM
Don't you know who I am?
Rydicule's Avatar
Isn't Injen a WAI?
The drop in filter is nice for the convenience of it, although some will tell you it lets more dirt into the engine, etc. As far as INTAKES go, I don't think I really like em. I love my low-end torque, as I tend to shift around 2k rpm 90% of the time, an intake would have me feeling like I lost power rather than gained it for the most part. I know they are supposed to give awesome gains top end, but I'm rarely up there, I would suffer the low-end loss mostly.
Rydicule is offline
Old 02-08-2007, 06:05 AM
JohnWEngle's Avatar
I use them in all my vehicles. My personal recommendation is to buy 2, that way you can take the dirty one out and put a clean one in and not have your can out of commision while cleaning the filter. Then you can take your time cleaning and re-oiling the dirty one. It is really important to make sure that the filter is dry prior to oiling. And it is also really important to not over-oil the filter media, which is very easy to do. In fact, I always allow my re-oiled filter to "drain" at least overnight (several days seems to be better) to avoid over-oiling, hence my recommendation for buying 2.
JohnWEngle is offline
Old 02-08-2007, 10:40 AM
MyBlue02's Avatar
G.A.B. and a k&n drop in...still have low end (at least i do) with the gab...and you get a nice bump up top...still using paper here till spring and hte dusty roads get cleaned
MyBlue02 is offline
Old 02-08-2007, 12:06 PM
Topher3284's Avatar
Thanks for all the good feedback. I will definitely look more into it and possibly get 2 ( Good idea JohnWEngle) I have little time on my hands as it is with having school and work.
Some of you recommended CAI, but isn't WAI supposed to be better? Check this out, under: what intake should I get... But I would like to hear personal opinions.
http://forums.maxima.org/showthread....45#post1832245
Old 02-08-2007, 01:05 PM
99BlackMaxMS's Avatar
This website helped me out a lot. In the end I just stayed with the stock paper filter mainly because I was not going to upgrade the intake.
http://www.bobistheoilguy.com/airfilter/airtest1.htm
99BlackMaxMS is offline
Old 02-08-2007, 08:44 PM
housecor's Avatar
Good luck
Woah, where is your filter?! For your engine's sake, I hope you're not running your car with nothing but a course green strainer for an air filter...
housecor is offline
Old 02-08-2007, 11:53 PM
reeloop's Avatar
He is still using his stock airbox, where the filter is.
reeloop is offline
Old 02-18-2007, 05:30 PM
RodzMax2002's Avatar
i still have my stock air box, i just bought a K&N air filter. id recommend it, a little extra power.i guess my car was being robbed of horsepower because now. it seems like it wants too go when i not even trying to push all that hard..
RodzMax2002 is offline
Old 02-20-2007, 07:53 PM
babyboyws6's Avatar
I was reading around the forum...
Injen "CAI" aka "WAI" since the sir filter is so small that replacing that one with a K&N universal air filter (those big truck intake looking ones) will drop a few more hp. havet tried it but in the process of doing so... just gotta order the parts and test them seperately... if anyone has done this and has the dyno sheets... please post them up.
babyboyws6 is offline
Old 02-20-2007, 08:00 PM
dot dot dot ...
NmexMAX's Avatar
What parts are you going to test?
NmexMAX is offline
Old 02-20-2007, 08:16 PM
babyboyws6's Avatar
Injen CAI.
and a Universal K&N air filter (K&N RU-2820)
Old 02-20-2007, 08:37 PM
dot dot dot ...
NmexMAX's Avatar
The placement of the filter has more to do with performance than the size of the filter.
NmexMAX is offline
Old 02-20-2007, 08:59 PM
babyboyws6's Avatar
well yes that is true... but the injen does pick up the most hp nd trq i know of...
it's not place behind a radiator or right next to the engine... as i heard... it pick up some good air. but the Air filter on the injen intake its self is so small....
Theres this closed thread... if you search around you will find it... topic is.. Injen vs others need opinion or soemthing down the lines of it. i read the whole thing so ima compare the 2 when i do get em in march.
Old 02-20-2007, 09:23 PM
dot dot dot ...
NmexMAX's Avatar
If you can show me a dyno where an injen put down more than my POP charger, I'd feel free to admit I'm wrong. Until then
NmexMAX is offline
Old 02-20-2007, 10:26 PM
Cletus
SoonerFan's Avatar
i want in on this too...Injen vs my Berk
people that buy the injen marketing hype instead of listening to experienced people on the org
i love the people that buy them...than try to argue their worth (with no proof)
SoonerFan is offline
Old 02-20-2007, 10:44 PM
reeloop's Avatar
Thats why people come back to this website, smart and experienced people
I learned alot through this forum thanks to you guys!
especialy advanced motor chat, interesting stuff
reeloop is offline
Old 02-21-2007, 05:51 AM
Trurida18's Avatar
so your saying a Berk Intake is better, and offers better performance than an Injen Intake?
Trurida18 is offline
Old 02-21-2007, 06:04 AM
dot dot dot ...
NmexMAX's Avatar
In plain English, yes.
NmexMAX is offline
Old 02-21-2007, 06:06 AM
Trurida18's Avatar
i guess ill be reaserching them now
Old 02-21-2007, 06:09 AM
Cletus
SoonerFan's Avatar
the berk is better all around...better performance and value
Old 02-21-2007, 06:17 AM
Trurida18's Avatar
gotcha.....so basically the fact that a Berk Intake is shortRAM means nothing, seeing as how they all suck in WARM air for the most part?
also what intake do u have under your hood?
Old 02-21-2007, 06:30 AM
dot dot dot ...
NmexMAX's Avatar
> you
....my Berk
Let's not dwell into intakes again
NmexMAX is offline
Old 02-21-2007, 07:47 AM
heresmymind
place intake under headlight bracket outside of engine compartment for true cold air intake... (this is a 3rd generation VG custom cai I made)
Old 02-21-2007, 08:18 AM
babyboyws6's Avatar
ill get my boys dyno ... he has an injen and it added 15 hp or 20hp 2 the wheels... adding a larger filter to allow more airflow makes sense dont it. intakes have to be properly installed for maximum performance. I live in New York, so a cold air intake for me makes sense rather then short ram picking up warm air. (cold air is like crack... makes the car bug out) haha
Old 02-21-2007, 09:44 AM
dot dot dot ...
NmexMAX's Avatar
If we’re going to talk intake stuff…again then…..
We’ll use real data. I want to do more comparisons using various set-ups.
This morning (temp in the mid – upper 20’s F) my IAT’s never went above 60*F (stock set-up of course )
And my MAF maxed out @ 168 gm/s @ 7070 RPM
Although MAF placement on these vehicles is not a very accurate way to tell if there is an increase in power.
This can be seen when comparing AFR data. Place the MAF in a very high flow area and see the increase in voltage &/or gm/s. But the AFR tells that the reading is wacky, (aka dumping way too much fuel in).
But I still think it does compare when there is more flow detected. I saw a small percentage drop when going back to my stock airbox (w/ FC straight pipe) And saw the same drop when trying a larger MAF housing. But that is not related to what I was referring to about flow.
NmexMAX is offline
Old 02-21-2007, 10:05 AM
babyboyws6's Avatar
well said... does anyone else have a different set up that works well for them
Old 02-21-2007, 03:07 PM
Cletus
SoonerFan's Avatar
Old 02-21-2007, 04:16 PM
babyboyws6's Avatar
hey bro, i will get the dyno and show you sooner or later... possibilities are endless
Old 02-21-2007, 04:37 PM
Cletus
SoonerFan's Avatar
you couldnt even give me an exact number...you said "15 to 20" cause you pulled it out of your @ss and/or took injen's word for it.
another person that doesnt want to listen to experienced people on here.
Old 02-21-2007, 07:46 PM
babyboyws6's Avatar
first of all dont be gettin at me like that cuz i aint listenin to you. I dont know you and dont care who you are... all u are here to do is give advice... take it or leave it. dont tell me im pullin sumthin outta my A$$ famz, i aint disrespect you so dont do it to me. People got different opinions on different things dont become a little girl becuz im not taking yours. Free country right?
that why people have different things buddy. oh yeah like i said my friend has an injen intake system and got a dyno test done... i said before i would try and get my hands on it to show ya.. did you miss that part?? not once did i say.. well injen says this and that.... not once so where you comming from with this..??
yeah i aint give u an exact numba cuz i aint sure bout hisz gains havent had the chance to meet up with em yet and take a look at the sheet.
dont label me as another person that doesnt wanna listen to experienced people... i'll take peoples advice, but certainly not from an A$$hole like you yo
Old 02-21-2007, 07:52 PM
is invisible
CoolMax's Avatar
This should be good...
btw...
CoolMax is offline
Old 02-21-2007, 07:56 PM
Topher3284's Avatar
Here it comes... might as well start play
Old 02-21-2007, 07:57 PM
Topher3284's Avatar
Oops I can't speak english either
Old 02-21-2007, 09:57 PM
Cletus
SoonerFan's Avatar
1. please put this in english that an adult can understand
2. repost.
thanks
FYI, the performance increase of an intake isnt an opinion...its a fact.
Quick Reply: K&N Intake for 2k2 recommend???
