Can you identify what this is under car? (pic)
Old Feb 8, 2007 | 07:05 PM
steelymatt's Avatar
I was looking under my car the other day and I saw this rope-like thing hanging down. The picture was taken on the drivers side of the car facing the front of the car. The rope is attached to a bolt. I'm just trying to figure out why it was just hanging there not attached to anything. I didn't see any wires running through it. It sort of feels like a thick shoelace. Does anyone know what this is?
Old Feb 8, 2007 | 07:09 PM
Johnbrooks302's Avatar
catalytic converter grounding cable
Old Feb 8, 2007 | 07:10 PM
Originally Posted by Johnbrooks302
catalytic converter grounding cable IIRC
someone will confirm for sure...
Old Feb 8, 2007 | 07:11 PM
02nismaxlegnd94's Avatar
cat ground, nothing to worry about.
upstatemax's Avatar
Yes it is... Pull it off and throw it out.
Old Feb 8, 2007 | 07:12 PM
steelymatt's Avatar
Hmm, I wonder if this has anything to do with why I'm getting code 0420 for the cat.
Old Feb 8, 2007 | 07:51 PM
AllGo's Avatar
This strap helps ground the exhaust and in turn your O2 sensors.
Of course the exhaust manifolds bolt to your heads/block which is grounded but the gaskets used throughout the exhaust system prevent a good consistent grounding point. You can imagine that proper O2 feedback is important for the ecu therefore this grounding strap is necessary.
Don't throw it away as someone else stated.
Old Feb 8, 2007 | 08:01 PM
Lumbee1's Avatar
How is a shoelace attached to a bolt hanging from the bottom of a car work as a grounding strap?
Old Feb 8, 2007 | 08:05 PM
The Law's Avatar
I R The Law
Old Feb 8, 2007 | 08:26 PM
steelymatt's Avatar
But the end that's hanging looks torn, like it was ripped off from something. Is the end that's hanging supposed to be attached to the cat?
Old Feb 8, 2007 | 08:32 PM
Stardust's Avatar
F---ing Kangaroos
Originally Posted by AllGo
Throw it away as someone else stated.
Correction......
Old Feb 8, 2007 | 09:18 PM
wyche89's Avatar
yeah, i have the exact same thing hanging from my car.. so we should cut it off then? cause i dont want it to get caught on anything i may run over
Old Feb 8, 2007 | 09:55 PM
Stardust's Avatar
F---ing Kangaroos
Yes 99% of us just ripped it off.
Old Feb 9, 2007 | 03:46 AM
Scruit's Avatar
U wanna try me young boy?
It's there for a reason. Look for the other end of the grounding strap.
Scruit's Avatar
And quit running over stuff.
Old Feb 9, 2007 | 05:37 AM
AllGo's Avatar
The manufacturer felt that this grounding strap was important or they wouldn't have installed it in the first place. The length of this strap may have allowed excess slack which would allow it to get hung up on things below the car and get torn, as many have mentioned. You may not notice immediate problems, but as someone stated it could trigger a CEL, and potentially fail at inspection time. This particular strap on our cars connects to one of the ~17mm cat bolts.
It seems that some people, stardust, have no clue as to what is going on under an automobile. The majority of automobiles built today, use mulitple cats/O2s, and indeed have some form of grounding strap connected to the exhaust.
Old Feb 9, 2007 | 05:47 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Mine as well as a few others I know for sure have removed theirs when it's come loose and have not had any adverse affects from doing so. It's been over 2 years for me, no codes. It's not that crucial.
Old Feb 9, 2007 | 06:15 AM
nismopc's Avatar
With all the talk over the past year or two about grounding kits and what not, why wouldn't this be any different? If anything, I'd consider replacing the braded grounding strap with a thicker gauge, not removing it.
Grant it no one has seen any ill-effects from removing it, but why not take advantage of the grounding possibilities here.
Not to mention, it would increase good grounding to the O2 sensors as stated in previous threads.
Old Feb 9, 2007 | 06:22 AM
upstatemax's Avatar
Considering there are no O2 sensors anywhere near there on any Cali spec car like more than half of 00's, almost ALL 01's and all 02-03's... It is useless.
If you have a Fed Spec... It might be usefull, although very unlikely.
Old Feb 9, 2007 | 09:19 AM
steelymatt's Avatar
Can someone take a picture for me of what bolt it's supposed to be attached to on the cat?
Old Feb 9, 2007 | 11:39 AM
NewLoveI30's Avatar
I just let mine hang... In case some very small person wants to Indiana Jones it underneath my car.
And if you really want to replace it, any of the bolts on the cat will do.
Old Feb 9, 2007 | 12:43 PM
CCS2k1Max's Avatar
Not needed. Ripped it off 3 plus years ago.
Old Feb 9, 2007 | 01:03 PM
Larrio Motors's Avatar
Boss Chen Industries
The cat has bolts coming out of it. The other end is held on between the cat bolt and a nut.
Both ends look identical
Old Feb 9, 2007 | 01:14 PM
Gle03Max's Avatar
If I'm not mistaking, o2 sensors have each their own grounds anyway.
Old Feb 18, 2007 | 06:43 PM
FanaticMadMax's Avatar
I've never seen that before, not even on my car, look like you ran over a jogger and caught his shoe lace, LOL. But that does look like a shoelace though but I never heard of any kind of grounding for a cat.
Old Feb 18, 2007 | 06:44 PM
Hey Larrio, your car looks great, what kind of tires size are you running on, since I like to change my SE stock rim and get something fatter tires make it look aggressive. your car is a beaut. Wish Mine was that color but I'm stuck with the Sherword green but hey it still lustrious and shiny
Old Feb 18, 2007 | 06:56 PM
upstatemax's Avatar
http://forums.maxima.org/private.php?do=newpm&u=53482
I guess it works really well...
Old Feb 18, 2007 | 07:25 PM
Arek's Avatar
Apparently it grounds catalytic converter to prevent (slow down) it corrosion.
Old Feb 19, 2007 | 12:38 AM
lalaMAX's Avatar
i had that thing hanging for 2 month... by the time i want to fix it... the wire is gone><...
been driving without it for 6 months... no problem at all... didnt feel anything too....
Old Feb 19, 2007 | 06:48 AM
Teddie18's Avatar
Reattach it. I'ts very easy. I did mine in about five minutes.
Old Feb 19, 2007 | 05:52 PM
Stardust's Avatar
F---ing Kangaroos
Climb under you car and look at the factory b-pipe and the nice crimps in it. PLEASE tell me the manufacturer thought that was important and thats why its there.
You clearly have no idea about how the 5th gen maxima works.
Old Feb 20, 2007 | 08:22 AM
Trurida18's Avatar
yea i got the same thing hanging down from my car.......
Old Feb 20, 2007 | 10:13 AM
kdaullary's Avatar
MINES A FED SPEC 01 SE TOOK MINE OFF WHEN I NOTICED IT HANGING DOWN. NO PROBLEMS AROSE FROM ME DOING THAT
Old Feb 20, 2007 | 11:10 AM
2002 Maxima SE's Avatar
Ah yes, the Fleisman rod. I recognize it because it is just south of the Hammer-Dorfman joist assembly.
j/k
Old Feb 20, 2007 | 12:37 PM
Trurida18's Avatar
so should i attempt to reground the strap, because its just dangling.....ive always wondered what the hell it was but now im just trying to determine if i should cut it off, or reground it........OR JUST LEAVE IT ALONE
Lakersallday24
Jun 16, 2019 01:35 AM
Quickgtp
Apr 13, 2017 03:30 PM
halfpol
Aug 5, 2015 08:24 PM
