Removing the axel bolt....
Old Feb 9, 2007 | 06:00 AM
doublea's Avatar
Long story short the big bolt on the axle wont come off, I even tried a two feet breaker bar, should I use a 3 feet pipe to extend the breaker bar ?
Any though ?
AA
Old Feb 9, 2007 | 07:09 AM
NisTech's Avatar
spray penetrating fluid and you can clean the threads with a wire brush. Then get a breaker bar with some thick pipe over it to get more leaverage and look away so it wont snap in your eyes or wear safety glasses and watch your knuckles.
I just use a Titanium IR impact wrench haha. Never fails
Old Feb 9, 2007 | 06:01 PM
DAP's Avatar
DAP
I've had success by heating the nut with a propane torch and using breaker bar/extension. Make sure the nut is not wet from penetrating oil when you heat the nut. Also, you can always find a mechanic who can loosen it, avgerage charge, $5.
Old Feb 9, 2007 | 06:05 PM
irish44j's Avatar
retired moderator
Snap-On impact gun works every time
Although I did once use a 4 foot cheater pipe on my 18" breaker bar. That worked too.
Old Feb 9, 2007 | 09:01 PM
DOHCtorJT's Avatar
PB Blaster, a "cheater pipe" on a breaker bar and some elbow grease.
Old Feb 9, 2007 | 09:32 PM
mist max2000's Avatar
PB Blaster
stuff works wonders
Old Feb 9, 2007 | 09:40 PM
DOHCtorJT's Avatar
and smells yummy too!
Old Feb 10, 2007 | 04:59 AM
doublea's Avatar
Ok I finally got the sucker out, I heated the nut with a torch then I sprayed WD40 on the stud and use the breaker bar to remove the nut. Thanks for your help guys I'll post some pics later.
Cheers
AA
Old Feb 10, 2007 | 04:02 PM
irish44j's Avatar
retired moderator
Cheers
AA
just for future reference...WD40 is not really a penetrant...it's more of a light lubricant. It will work, but PB Blaster and Liquid Wrench work much better for breaking stuff loose.
Old Feb 10, 2007 | 04:52 PM
SoonerFan's Avatar
Cletus
i have learned from experience several times that liquid wrench works better than WD-40.
if it squeaks - WD-40
if its stuck - liquid wrench
Old Feb 11, 2007 | 06:38 AM
doublea's Avatar
Hey guys, once I have heated the nut with a torch, I then sprayed the WD40 on the axle and not the nut, with the 2 foot breaker bar it came off almost easily.
Old Feb 11, 2007 | 07:11 AM
SoonerFan's Avatar
Cletus
that was the heat...not the WD40
Old Feb 11, 2007 | 11:11 AM
A33 VQ30DEK's Avatar
impact gun works the best. =)
my03maxima
Jul 28, 2024 07:40 AM
user 11122324
42
Jul 18, 2022 03:35 PM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
