SLIP and TCS OFF lights are lit up.
Old Feb 10, 2007 | 01:49 PM
zethus25's Avatar
I have a 2002 Maxima automatic transmission. I keep my maxima in great condition with periodic servicing, oil changes, etc.
I was driving on the highway doing about 35/40 mpr. The road was inclined so I was going uphill at the time. I hit the gas to accelerate and I felt the transmission miss the higher gear. As this happened, the SLIP and TCS OFF lights lit up, as well as the check engine light. The car wouldn't upshift and I had to slow down and pull over.
Currently, the all three lights (SLIP, TCS OFF, CHECK ENGINE) are lit up and the car will not drive in the higher gears. My battery is relatively new, however after this event, the battery has been acting a little shakey as well.
Is this a transmission problem or something else? Where can I take my car other than the Nissan dealer and what do I tell them I need fixed?
I'm a novice when it comes to car problems, so any advice, suggestions or comments would be very helpful.
James
Old Feb 10, 2007 | 01:56 PM
RLW001's Avatar
Go to AutoZone or Advance Autoparts and have them read your codes, there is no charge. They may even be able to give the diagnosis.
Old Feb 10, 2007 | 02:34 PM
Project323
could be something that sets check engine light on, and slip/tcs are just follow up lights.
Old Feb 10, 2007 | 02:40 PM
upstatemax's Avatar
This usually happenes when a/many coils bite the dust.
Old Feb 10, 2007 | 03:01 PM
zethus25's Avatar
I just got back from autozone. They check my codes. P1102 (Mass Airflow Sensor) code was displayed on their testing device.
Is this something I could replace easily on my own or do I have to go to the dealer? Also, how can I be sure that replacing the Mass Airflow Sensor will fix all the lights?
Old Feb 10, 2007 | 03:32 PM
zethus25's Avatar
I'm confused. I've seen many people on here dispute whether the (SLIP, TCS OFF, CHECK ENGINE) light problem is the MAF sensor or a failed coil pack. I would hate to replace the MAF sensor only to find out I have a failed coil pack.
How long would it take an amature to replace the MAF sensor? How about a failed coil pack?
Old Feb 10, 2007 | 04:08 PM
xxbeats's Avatar
i personally dont think its a maf sensor problem that you felt.can you have a problem with it yea ,maybe you have multiple problems. i do work at a shop could help you if you want?
upstatemax's Avatar
Both are very easy to replace and I know a MAF can usually be tested.
And I think a coil pack can be tested also.
If it is a coil pack you can bring it Nissan and they should be able to tell you exactly what coil it is.
If you are getting a MAF code... chances are it is that, usually a MAF is toast when you cannot rev past 3,000rpms.
Old Feb 10, 2007 | 04:40 PM
SilverGLE's Avatar
I'm watching you, boy...
That's the exact test I would recommend! My MAF took a dive and the pull from acceleration would drop off at 3.5k, but the rpm's would keep climbing.
Old Feb 10, 2007 | 06:07 PM
zethus25's Avatar
xxbeats,
where is your shop? Can you replace coil packs and/or MAF sensor and if so, how long you think it might take? Cost estimate?
Old Feb 11, 2007 | 11:13 AM
xxbeats's Avatar
im in north plainfield, 07060 call 908-561-3100 on mon i'll be there till about 3pm ask for javier ,we'll talk
mvm062
Nov 30, 2020 09:00 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
MaxLife17
Sep 8, 2015 02:36 PM
A32goldylocks
Sep 2, 2015 06:39 AM
vrajesh123
Aug 31, 2015 11:00 AM
