installing fog lights on a gxe
Old Jul 6, 2001 | 12:05 PM
merlin_2001
has anyone installed factory fog lights on a 2000-2001 GXE. I would like to install some factory nissan fog lights on my GXE. Has anyone done it before???? and whats needed.
Old Jul 6, 2001 | 12:19 PM
DenMax's Avatar
FAQ U
If you go to www.courtesyparts.com and go to the fog light purchase they have a little instruction page to click on.
Try this:
http://www.courtesyparts.com/onlines...3_acc_exterior
Old Jul 6, 2001 | 03:00 PM
irvine78's Avatar
everything u need comes in the box except tools.
tools you need are a phillips head screw driver, and 10mm socket and a rachet.
since the car already comes pre-wired, you just gotta connect the wires and install the switch(which also comes in a box....)
i got mine installed in an hour....
Old Jul 6, 2001 | 03:11 PM
Dario's Avatar
yeah i did the install a long time ago and it took about an hour...pretty easy the wires are all prewired so u just hook up the connector from the fog light to the taped wire inside the fog light hole and the hardest part is just unhooking the old turn signal switch other than that its pretty easy have fun
Old Aug 5, 2017 | 07:00 AM
Chad Snider's Avatar
So is the factory fog light switch on the turn signal stalk or is it a push button switch on the dash? Just wondering where the wiring for the switch is located
Old Aug 5, 2017 | 09:20 AM
DennisMik's Avatar
The fog light switch is part of the headlight switch. You get one in the kit. You twist a ring on the headlight stalk.
Old Aug 5, 2017 | 08:58 PM
Awesome. Do you have an updated link for the kit? The one above doesn't work anymore
Old Aug 6, 2017 | 04:34 AM
DennisMik's Avatar
Try this - http://www.courtesyparts.com/?p=cata...%20light%20kit
If it doesn't work go to www.courtestparts.com and type FOG LIGHT KIT into the search box at the top.
I have heard that the kits are becoming scarce, so maybe you want to call them and ask. The phone is on the top right corner.
Old Dec 31, 2017 | 12:27 PM
[QUOTE=DennisMik;9154289]Try this - http://www.courtesyparts.com/?p=cata...%20light%20kit
If it doesn't work go to www.courtestparts.com and type FOG LIGHT KIT into the search box at the top.[QUOTE]
Where is the plug that plugs into the new turn signal stalk. I can’t find it anywhere
Old Dec 31, 2017 | 05:25 PM
Derrick2k2SE's Avatar
Did you buy these new? I see these in the salvage yard all the time. You could pull all the pieces you need for around $20.00
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
