AEM Dryflow
Old Feb 18, 2007 | 10:40 PM
CRBWS6's Avatar
AEM Dryflow
Berk has replaced the K&N with this newer dry-type, cleanable filter which was first introduced in late 2005. The claims are:
1. ease of maintenance
2. reduced risk of maf damage
3. greater filtration than oiled filters
Upon reviewing the limited info online regarding this filter, my initial thoughts are:
1. true
2. true (gross overoiling is taken out of the equation)
3. maybe so, but the likely trade-off is flow (power, responsiveness)
Overall, this sounds like a nice compromise between oiled filters (K&N) and more expensive, non-cleanable dry type filters (Apexi).
The question is, does anyone have specific long term (i.e. at least one cleaning cycle) experience with the AEM Dryflow?
Old Feb 18, 2007 | 10:44 PM
SoonerFan's Avatar
Cletus
i wouldnt buy anything from AEM...but thats just me.
im good with my apexi
Old Feb 19, 2007 | 01:28 PM
CRBWS6's Avatar
specific bad experiences w/AEM?
and how long has the apexi lasted you so far?
Old Feb 19, 2007 | 01:34 PM
maxximaa's Avatar
i wanna find out which ones i should get too...more comments plz...
Old Feb 22, 2007 | 06:00 PM
CRBWS6's Avatar
bump...no one has this setup yet?
Old Feb 26, 2007 | 07:08 PM
DOHCtorJT's Avatar
Bought this setup used from the FS boards last week. Just installed it tonight.
Now I'm just as much as an air filter fanatic as anyone, and I gotta tell you, this AEM thing is impressive. Every year I go to SEMA, I end up feeling around inside the cone filters for how the rubber molding is shaped on the inside. This is the ONLY filter I've found that is actually radiused to the outlet, providing a real smooth airflow path. The quality of the filter media is nice and well assembled, I have no reason to disbelieve AEM's lifetime warranty claims. This filter has 1000 miles on it, and I'll probably clean it in December (AZ dry/dusty summer FTL).
As for power....well it's worth every penny (even had I paid full price ).
Old Mar 7, 2007 | 07:36 PM
Merlyn's Avatar
And... I'm out
I have the AEM filter as well, and I have had it for a good 3k miles and I can't say any problem with it at all. Then again a filter is a filter to me but I cant complain about it, never looked back (they told me they were out of the A'pexi and would give me the AEM for the price of the oiled when I purchased mine)
Old Mar 8, 2007 | 06:50 AM
AnDyMaN's Avatar
i had a injen cone filter on my car, then changed it to the dry flow.
i felt like the dry flow was a little better. it felt a little more "responsive" and a little "faster". maybe by milliseconds, but nonetheless.
I was never really impressed with the injen filter. I hear its a K&n filter, but i don't know. i guess im not used to all the carbon build up and stuff that occurs every 1000 miles.
i think biggest difference would be maintainence.
Old Mar 8, 2007 | 07:23 AM
aptgrk's Avatar
I have had the AEM Dryflow filter attached to an injecn CAI for about 8,000 miles. I've heard from an old Ford forum that oiled filters such as K&N can contaminate the MAF. It really doesn't matter what I have heard, just a matter of what I think, and I do believe that small particles of oil, especially after cleaning, can be sucked into the sensor, so why take a chance? Why the hell is everybody's MAF's going bad, not just on our Nissan's? Sure, it could be some sort of defect, but I'll bet that its from these filters. I'm sure people will say they've had no problems, but I just believe oiled filters will increase the prob. that contamination could occur.
I'm not sure what type of filter was on my car before, I thnk some sort of foam type, but the AEM performed the same or better in terms of response and power, all of course based on feel. Basically, I would recommend it.
Old Mar 8, 2007 | 11:58 AM
SoonerFan's Avatar
Cletus
after seeing a pic of the filter...even though it is larger than the apexi, the apexi has a better design and actually gets more air in to the throttle body.
with the filter above, the air gets sucked in the the center of the filter, then gets sucked to the throttle body. with the apexi, the funnel direct air straight to the throttle body.
Apexi - "Funnel shapes focused on increasing air speed without changing the flow direction of the intake air. The result is a high speed and smooth flow of air into the intake."
Old Mar 8, 2007 | 11:59 AM
SoonerFan's Avatar
Cletus
that has been disproved many times on here.
if you use the filter correctly, it will not cause a problem with the MAF
Old Mar 8, 2007 | 05:16 PM
DOHCtorJT's Avatar
The outlet of this filter is "venturied" on the inside, which smooths out the air. The motor is only going to take the air it needs, when it needs it, so the air speed isn't that much of a benefit, especially where the Berk/FC intakes place the filter. Don't get me wrong, the apexi is a great filter, but it's high price and disposable nature isn't justified by the well written marketing
I'd love to see a dyno comparo of filters alone.
Old Mar 8, 2007 | 05:19 PM
SoonerFan's Avatar
Cletus
dynoing a filter alone is hard since the car is sitting still and not getting the normal flow of air it gets when its moving.
honestly though, the difference is probably 1/2-1 HP with any intake and filter
Old Mar 9, 2007 | 07:17 AM
aptgrk's Avatar
Use the filter correctly? Are you talking about an incorrect installation. or maintenance? The only way you "use" the filter is to drive your car. In the case of maintenance, then I would agree, especially if you do not let it dry enough after cleaning.
I understand it has been disproved, but people have also agreed with my opinion. I believe the chance of contamination increases with use of an oiled air filter.
Old Mar 9, 2007 | 08:42 AM
knight_yyz's Avatar
Toolie
I've had my AEm for about 6 months now on a "berk style" short ram intake, I have a injen hydroshield wrapped around it. Works fine with no problems. I switched because I took apart my maf one day to clean it and found little bits of oily red foam sticking to the mesh of my MAF.
Old Mar 9, 2007 | 01:15 PM
SoonerFan's Avatar
Cletus
i mean proper maintenance
independent places have done extensive testing on the K&N filters and it didnt cause a MAF problem. dealerships blame them for MAF problems to push the blame somewhere else. they also try to discount the K&N so they can continue to sell people nissan filters.
Old Mar 10, 2007 | 11:29 AM
IloveVQ's Avatar
I have the DryFlow filter and it works well. had it for about six months now and no problems. IMO filters are kinda just filters. as long as its a name brand like aem or apexi, works fine, and it doesnt cause maf problems or whatever then who cares?
Old Mar 10, 2007 | 01:21 PM
truesports03's Avatar
i bought the berk tech cai w/ AEM filter in dec. and it is awsome. the sound that it makes all the way throw the power band. i would recomend it to any body, even my buddy with a 04 max got rid of his apex for this aem dry filter.
Old Mar 10, 2007 | 01:43 PM
sascuderi's Avatar
Where can you get the AEM filters???
Old Mar 11, 2007 | 09:05 PM
CRBWS6's Avatar
cardomain is one of many places....
Old Mar 12, 2007 | 07:09 AM
releasedtruth's Avatar
rilla dope
I've damaged a maf with a K&N, even though I used the very lightest oil and let it dry for nearly half a day in Arizona air. My mechanic hates oiled filters and he's the mechanic that designed some of our finest Max parts. Thankfully he cleaned the maf before it fried out. I could tell from the surging that it was jacked.
Old Mar 12, 2007 | 04:29 PM
kdaullary's Avatar
I have to agree. i have used k&n filters for years on mustangs with cai kits and ive never fried a maf sensor. although ive never seen the extensive testing of oiled filters. side note the nissan filters have an oil film on them also.
Old Mar 18, 2007 | 12:22 AM
kingrukus's Avatar
no more maxima...
The only reason I am currently afraid to go back with K&N is because of their lack of filtering...just isn't worth it IMO for the 1 or 2 extra horses over a dry filter.
I have the Apexi right now, not installed yet. Anyone know how many miles these things are supposed to last for before replacement under average driving conditions?
I am not too fond of dumping and replacing the Apexi every so often, and so the AEM is starting to seem like the best choice for me since I want to stay with a dry filter.
Old Mar 18, 2007 | 11:41 AM
blkAEmax82's Avatar
Glory Glory Man United
Thanks guys for putting this Thread up .. Lots of good Info .. How can you tell when your MAF is going bad or how do you clean it? Im suppose to get my Berk INtake with the AEM filter this week ..
Old Jul 16, 2007 | 08:20 AM
big h's Avatar
for those with the 01 setup...which cone size did you get...
2.75"x5"
or
3.0"x5"
Old Jul 16, 2007 | 08:33 AM
big h's Avatar
found the answer via search...just had to dig deeper and be patient
3.0"x5"
Old Jul 16, 2007 | 03:16 PM
S.S.Engine's Avatar
A reason would be nice and informative instead of stating your opinion.
AEM/DC Sports are very good and reputable company.
Old Jul 16, 2007 | 06:59 PM
The Law's Avatar
I R The Law
It would be nice if you read the thread, stupid newbie.
Old Jul 16, 2007 | 07:31 PM
SoonerFan's Avatar
Cletus
i have to give my reasons in EVERY freaking thread talking about this?
if you had done some research, you would know the reasons
Old Jul 16, 2007 | 08:52 PM
S.S.Engine's Avatar
Yes stupid newbie. I like how much credential I have due to a title and my post count. But according to your system I must be dumb. I better create a thread asking what an intake does. My bad for not holding more weight in this forum. I guess I'll keep my comments and help to myself.
Nope, but I sorta left my comp on and somehow decided to post and became old news. But still nothing wrong with AEM and I wasn't aware you posted a lot of info about the filters, since I am a newbie.
Old Jul 16, 2007 | 08:54 PM
CoolMax's Avatar
is invisible
27.09 posts per day
Old Jul 17, 2007 | 08:21 AM
S.S.Engine's Avatar
3.31 posts per day
I win....?
Cotozic
Jun 28, 2017 08:01 PM
hlh0501
Aug 6, 2002 07:25 AM
SnowMax
May 23, 2002 04:46 PM
MyownNismo
Apr 8, 2002 12:04 PM
