Hookin up power seats. Need some Help.....
Old Feb 21, 2007 | 06:28 PM
choppy718's Avatar
Hookin up power seats have been easy until now. Need a lil help figuring out where to get power for my passenger side seat. I had manual seats then got leather/powered. The driver side had the wires no problem. There were no wires to power my passenger side, i cut the harness plug from the max i took the seats from, all i need is to get power to the cord. This is what i am working with:
That little opening you see is where the wires are suppose to some from:
here is the wiring harness:
Here is where i think some power can be obtained:
Now all i need to know is where to run the wires to get power to that seat. Thanks in advance.
Old Feb 21, 2007 | 07:45 PM
LA02MAX's Avatar
That's interesting...mine has a wiring harness already there. Yours must have slipped up underneath the carpet or something. You can tap the power from somewhere else but you will most likely need an extension and you will need to route the wiring underneath the carpet for a clean install. Pull the carpet up first and check to see if the wiring harness is under there, because there should be one there. Mine even has a plug for heated seat switches taped inside the center console and my car came with cloth seats.
Old Feb 22, 2007 | 04:01 PM
choppy718's Avatar
nothing is there, I guess cuz i have a GXE
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
