Alarm question
Old Feb 23, 2007 | 02:21 PM
Mynameismcgyver's Avatar
Alarm question
Hello,
I have a 01 GLE that has a remote start using a Valet key. I cannot seem to figure out if the car has an alarm. Ive tried different button combo's but it will only lock/unlock the car. Did my car come stock with an alarm and remote start?
Old Feb 23, 2007 | 02:26 PM
erty67's Avatar
Decal Specialist
It could be just an add-on remote start. They allow you to use the stock keyless remote to activate. I don't believe remote start was a factory option
Old Feb 23, 2007 | 02:45 PM
SoonerFan's Avatar
Cletus
Originally Posted by Mynameismcgyver
Hello,
alarm - yes
remote start - no
what key fob do you have?
Old Feb 23, 2007 | 03:37 PM
Originally Posted by soonerfan
alarm - yes
remote start - no
Fob? Not sure what your asking?
Old Feb 23, 2007 | 03:47 PM
MIXXMAX's Avatar
The remote that you put on your keychain for your car alarm. Fob=Full of buttons.
Old Feb 23, 2007 | 04:47 PM
I knew that. http://www.mega-watt.com/Images/remote3.jpg
Old Feb 23, 2007 | 05:53 PM
EastSideMaxima's Avatar
A swift Bimmer driver
Did you try holding the right button till the parking light blink?
I've seen that setup to remote start...
Old Feb 23, 2007 | 09:57 PM
I will try tomorrow.
Thanks for your help. I will report back.
Old Feb 24, 2007 | 06:52 AM
Nothing. Tried holding it, pressing it two times etc... The thing is that when I press the left button.. the cars locks activate and the lights flash. The security light will also blink in the dash. The horn does not sound during all this. UGH!
Old Feb 24, 2007 | 06:55 AM
MacGarnicle's Avatar
horn not sounding doesn't necessarily mean the alarm isn't activated. If your lights flash and the security light blinks, chances are you're still arming your system.. you just don't have a panic button?
Old Feb 24, 2007 | 07:14 AM
No panic button. My whole problem is that I have alot of money in Audio equipment in the car. If you sit inside the car and open the door when the car is supposedly armed, there is no sound of the horn or lights.
Old Feb 24, 2007 | 07:27 AM
do you still have your stock remotes lying around somewhere? You might want to consider an upgrade to a system that integrates Alarm and remote start (Viper, etc)
Old Feb 24, 2007 | 08:07 AM
Then I dont think it's got a Remote Start built in...
You are probably better off getting a Viper unit put in...
I have a Viper 791 which I absolutely love!
Old Feb 24, 2007 | 09:52 AM
Hmmm I do not have the original remote as I am the second owner of the car through the dealer I work for. I wonder If I can purchase an orginal remote and see if that will activate the alarm. Wouldn't care If i had two remotes on my ring.
Old Feb 24, 2007 | 10:03 AM
It doesn't really make sense that the alarm is deactivated - could just be a matter of you not being able to arm it with the remote you have. I'd bet if you got a stock remote, you'd be able to arm the system.
Keep in mind though, that the stock alarm won't do anything to stop people from breaking in and stealing your audio equipment - it'll just stop people from taking your car (and only then, if they try to hotwire it or something). You might want to consider buying an aftermarket alarm - or at the very least, buy a shock sensor which your stock system can use (cheaper option, should only run around $10). I plan on doing this over the summer.
Old Feb 24, 2007 | 10:39 AM
Yeah, Im thinking a stock remote will prolly work. Then a Shock sensor would come in Handy.
Thanks, I appreciate the help alot.
Old Feb 25, 2007 | 07:54 AM
Dust N Bones's Avatar
Does your car have the little red Security Light on the dash that blinks when the car is locked? If that blinks than it should mean your alarm is activated. Another thing you can do is put your driver side window down, get out of the car and lock the car with the remote. Wait about 1 or 2 minutes then reach through the window and unlock the driver side door with your hand. Don't use the power lock button, just unlock the lever for the drivers side door. Now pull on the outside handle to open the door and when the door opens the alarm should go off. If not then you don't have an alarm or isn't being activated. I really thought all 5th gen maxima's had a factory alarm though.
Old Feb 25, 2007 | 09:09 AM
nsnrider's Avatar
+1, i am pretty sure all 5th gens come with an alarm unless you don't have the little red light next to your clock.
Old Feb 25, 2007 | 10:01 AM
The best place to purchase an OEM remote is probably Ebay.
This is the one you need: http://cgi.ebay.com/ebaymotors/2000-...QQcmdZViewItem
You can find the programming instructions here on the Org.
Old Feb 25, 2007 | 10:56 AM
Yes I have the red light and i have tried opening the door when it is supposedly activated. The alarm still has yet to go off. Im going to try the OEM remote and go from there. Thanks
Old Mar 6, 2007 | 06:26 PM
TIEL240's Avatar
factory alarm vs aftermarket alarm
Could the two alarms conflit each other?
Old Apr 2, 2009 | 08:24 PM
ridinwitha35's Avatar
Did you ever resolve this?
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
