battery problems
battery problems
I have not driven my maxima in about a month and decided to drive it this weekend. It did not start due to a dead battery (optima red top)so I used a small jump box to try and start it. The headlights and interior lights came on with the jump box but the car would not turn over. I was guessing it probably needed to get charger from another running car so I decided to jump it with my company car. I hooked up the jumper cables and tried to start my maxima but now I got nothing at all no headlight no interior lights which I thought was strange. After looking at the jumper cables again, I realized I hooked up the positive cable to the negative terminal and vice versa like a retard. Now the car won't start at all. Did I blow my starter or did I just blow a fuse. If it is just a fuse does anybody know where the fuse is so I can replace it. Thank you for the help guys.
check the alternator sounds like the battery is not getign charged while on start if you took it off and bring it to autozone they'll check it for you and i would recomend if its F****d up overhaul it much cheaper than buying a new one and better than buying a used one
Originally Posted by NisTech
That's just the main fuse...
Nothing wouldn't work if that would be out
JoshG
51
Sep 21, 2015 10:41 PM
markevans999
Sep 10, 2015 04:29 PM
