Remove Emblem from Center Cap?
Old Feb 28, 2007 | 10:41 AM
wadamax's Avatar
Has anyone had any success removing the Nissan Emblem (hamburger) from their center cap? I have 02-03 Stock SE wheels, but I think the center cap is used on other models. I want to stick my own emblem on the center cap, but because the surface is not flat, due to the Nissan, I can't. If not, can anyone tell me where I can get center caps without the emblem that will fit?
Old Feb 28, 2007 | 02:26 PM
irish44j's Avatar
retired moderator
get the centercaps from the infiniti G35 17s. You can pop the silver infiniti logo off. It leaves 2 little holes, but you can cover them up.
Old Feb 28, 2007 | 02:44 PM
wadamax's Avatar
thanks.
I knew it had to be a way to do this. Now let me hunt some down.
thanks
Old Mar 5, 2007 | 02:39 PM
wadamax's Avatar
I found some, but they are from G35 18's. Will they work also?
Old Mar 5, 2007 | 05:11 PM
kingrukus's Avatar
no more maxima...
I have a set of nissan center caps from 02-03 nissan wheels, and the hamburger came off after i sort of removed the rivits that they are attached to. It will leave too small holes however in the cap.
Old Mar 6, 2007 | 05:50 AM
wadamax's Avatar
When you say rivits are you refering to the 2 points in the back of the cap that appear to have glue around them. If so, what did you do to remove?
Old Mar 10, 2007 | 04:14 PM
kingrukus's Avatar
no more maxima...
Yup those are what I am referring to. My dad actually did it to a set of caps on his Altima SE-R wheels that he put on his accord coupe. I believe he used a drill bit and drilled them out without actually damaging the nissan logos.
Old Mar 12, 2007 | 05:46 AM
wadamax's Avatar
cool. It worked. They came off with no problem. thanks for the info
gigabyte
Jan 6, 2017 06:05 PM
05RLS2
Apr 14, 2016 11:49 AM
RealityCheck
Oct 2, 2015 06:34 PM
