having problems with my 2k1- stalllllling
Old Mar 2, 2007 | 04:52 AM
djbrown's Avatar
-Da MTL Brown Boi-
hey guys,
i have a 2001 stock auto maxima and yesterday nite while i was driving back home my car stalled suddenly running at around 40km/h.
now everytime i try to start thecar the engine starts cuz i seethe rpm going up and coming down right away n it stalls unless i keep on revving the engine.
but everytime i stop revving it stalls. i have to keep on revving and put it on D to make it run, but as soon as i reduce the speed it stalls again. i have ses, slip n abs sign but they were on since last year when i broke my abs sensor on rear wheel, beside that there was no prob.
i hope any of you can tell me wat could it be
THANKS
Old Mar 2, 2007 | 05:36 AM
artin64's Avatar
Read the SES code there should be another one besides the abs sensor code that u had sinc last year. that should tell u whats wrong.
Old Mar 2, 2007 | 12:27 PM
maxmama's Avatar
The same happened to me last night but I dont know much about cars (just learning). Plz let me know if you figure it out.
Old Mar 2, 2007 | 03:08 PM
djbrown's Avatar
-Da MTL Brown Boi-
yea i think i did, well after reading in the forums i figured its probably MAF, so i disconnected the sensor cable off and den i tried to start it and it worked but couldnt go over 2000 rpm. I put back the plug in and tried and it started doing the same thing again so i guess its my MAF sensor that is gone.
try the same test on ur car and let me know wat results u got.
Old Mar 2, 2007 | 03:21 PM
maxmama's Avatar
Well...I had a mechanic check my car out and I suggested it to be the MAF sensor. He said there are two sensors and they both could be out. I told him to try cleaning the sensor and he said he did, but i dont know cuz i wasnt there. He says he wants to charge me $90 tow to his shop, and $400 for one sensor. I think that is just for the part cuz he said he will use his discount and take $100 off. Do you think its easy enough to replace yourself? Did you try cleaning your sensor w/ sensor cleaner? Let me know what works for you.
Old Mar 3, 2007 | 12:46 AM
artin64's Avatar
There is only one MAF sensor, and yes replacing it is really easy, if u have a 5th gen then it shouldn’t cost u anything more than 100$ to buy and replace it yourself. If u have a 5.5 gen it will cost u about 400. However there are other ways and the guys in .org in here found another way to replace it with a 5th gen one. Remember always do a search before u post, there is a lot of good information and walkthroughs about this topic.
Old Mar 3, 2007 | 11:15 AM
djbrown's Avatar
-Da MTL Brown Boi-
this "mechanic" really doesnt know what he`s talking about, there is only one MAF sensor and if u order it online its around 100 dollars. the install is very easy to do so u can do it by urself and save urself some money. Nissan should really do a freaking recall on their MAF
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
