Help! Stop the Squealing!!! Awful squeal when turning left
It squeals whenever I turn left, and usually at about 10 mph+ or over bumps. I've done the things I researched.
I didn't do it when we got some torrential rain yesterday, so I don't know if that helps.
It's driving me crazy!
Any ideas?
- Installed a new bump stop cap and greased it up.
- Pulled back the brake dust shield.
- One of the shims was bent in toward the disc. Took it off, and bent it back into shape.
Any ideas?
Any ideas?
Any ideas?The last time I had these similar symtoms, i thought I had a bad bearing but it turned out that i need to have the drive axle splines re-greased. Now this is rare. But the fact that you mentioned rain brought up some bad memories because the squealing from the front end got worse when it rained. Again this is a remote possiblity so rule out everything else before checking the splines.
I sprayed the end links and surrounding area with PB Blaster, and the squealing stopped.
I was getting ready to replace the end links, and figured this would help when I actually start. This is definitely a nice bonus. No more squealing
I just did the Brakes on My 2k Max. And i think its either the Shims on the back of the pads or the dust shield as i had a pain in the A** time doing them before i got the Caliper Piston tool. Plus i still had factory Orig Pads. So they didnt want to come off very easily.
Was there any resolution to this? I also have this squealing sound any time I turn my wheel. Originally it was only when I turned left, now I get it when I turn left or right. It is worse on cold days, on some warm days I rarely get it or if I do it get it, it's only right at cold startup and then not for the rest of the day. Also, on cold startup when I try and turn my wheel, in addition to the squeal, there is some EXTREME resistance on my wheel so that I am almost unable to turn. Any idea's please? Thanks guys.
boomerbrian
Oct 31, 2018 10:25 AM
aminus21
Sep 12, 2015 04:53 PM
