ABS LIGHT (Can it cause the whole ABS system not to work??)
Old Mar 9, 2007 | 11:48 AM
maximamass's Avatar
I got a 2001 max and I got an ABS light on and I had an emergency stop today and the wheels locked up NO ABS pump NOTHING.
WHen you have a light on does it cause the whole system not to work?
Oh it seem like the right front tire locked more than any but its the driver side REAR sensor that is bad.
Old Mar 9, 2007 | 11:58 AM
NmexMAX's Avatar
dot dot dot ...
If one sensor is bad, the entire system wont work.
Old Mar 9, 2007 | 12:34 PM
fishpony's Avatar
yup ill second that. i blew a tire which cut my abs wire in the rear and i had no abs for about a week with snow on the ground.
Old Mar 9, 2007 | 12:44 PM
maximamass's Avatar
When you replace it does the light/system reset by itself or is it like a check engine light?
Oh yeah THANKS guys
Old Mar 9, 2007 | 01:15 PM
fishpony's Avatar
it should reset itself i believe.
Old Mar 9, 2007 | 01:16 PM
SoonerFan's Avatar
Cletus
the light didnt cause the problem
the problem caused the light to come on
Old Mar 9, 2007 | 02:41 PM
foodmanry's Avatar
Da Roller Coaster!
If the light doesn't reset after repairing fully disconnect the battery (remove both positive and negative terminals). That should reset the light.
Old Mar 9, 2007 | 03:20 PM
fishpony's Avatar
Uhhhhh...... he said the rear sensor was bad but was wondering if it caused his front wheel to lock up. and yes because of the rear sensor my guess is that abs will not work on any wheel. if your right side wheels both locked up and your left side didnt then you might have a problem. so when just get your rear sensor replaced and your abs light should clear out and abs should work fine, if that is the only problem. if it stays on then theres something else messed up.
Old Mar 9, 2007 | 05:38 PM
maximamass's Avatar
Thanks guys. I already had it diagnosed and its just the one sensor. I appreciate the help.
Where can I find a write up on the replacement? I know theres the how to's but does anyone have a better one or different one?
Old Mar 10, 2007 | 12:38 PM
maximamass's Avatar
Please let me know where a write up is. I dont see one in the tips and tricks and how to's
Old Mar 11, 2007 | 09:25 PM
NYC2K2MaXx's Avatar
do u have traction control on ur car? cuz im having the same prob only diff us that my tcs light is on along with the slip light... hope its just a abs sensor
Old Apr 17, 2007 | 09:27 AM
00MaxSE's Avatar
Pointy Elbows
My ABS light came on this morning. How can I find out which sensor needs to be replaced?
Old Apr 17, 2007 | 09:44 AM
NmexMAX's Avatar
dot dot dot ...
Some OBDII scan tools have an ABS option. So, with that said, maybe try AutoZone.
A rough inspection might be on hand before taking it to someone/place that will read it.
Cipher reads these codes, not sure of the AE does though.
Old Apr 17, 2007 | 09:46 AM
00MaxSE's Avatar
Pointy Elbows
Cool thanks. I may just stop at Autozone to see what they can do.
Old Apr 17, 2007 | 05:25 PM
00MaxSE's Avatar
Pointy Elbows
Hmm when I left work today, the light was OFF.
Old Apr 17, 2007 | 05:43 PM
NmexMAX's Avatar
dot dot dot ...
Was it the ABS light or, 'Brake' light?
Old Apr 17, 2007 | 06:29 PM
00MaxSE's Avatar
Pointy Elbows
Umm...ABS like I originally said.
Old Apr 17, 2007 | 06:48 PM
NmexMAX's Avatar
dot dot dot ...
I figured it was, since you're one of the more 'alert' members.
But I just had to ask, since it's more common for the Brake light to 'go away' due to fluid level.
Old Apr 17, 2007 | 06:59 PM
nsnrider's Avatar
sometimes if one wheel spins more than the other or locks up, the ABS light will come on and stay on for a bit, when you restart the car and start driving again, the abs computer will recieve the signals from the sensors that all wheels are turning at the same speed and will turn of the ligh. That said, if your abs light comes on due to a "situatio" (whatever it might be), turn of the car, restat it and start driving normally and it should go off.
Also, those of you with TCS, the traction control system works using the ABS sensors, therefore, if your ABS light comes on, TCS OFF should come on too. Follow above procedure.
Old Apr 17, 2007 | 07:02 PM
00MaxSE's Avatar
Pointy Elbows
That is some very good insight on your part.
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
2k0to2k3
Aug 18, 2015 09:59 AM
doobadoo
Aug 15, 2015 06:43 PM
kenc15
Aug 5, 2015 08:29 AM
