Torsen limited-slip differential
Old Mar 10, 2007 | 06:19 PM
alextothestars's Avatar
how does one know if they have the optional Torsen limited-slip differential six speed, as opposed to the normal six speed? this is something id like to know before i purchase one.
Old Mar 10, 2007 | 06:51 PM
MacGarnicle's Avatar
i thought the max's came with helical lsd?
Do a search, theres a way to tell by looking at your VIN
Old Mar 10, 2007 | 07:51 PM
SoonerFan's Avatar
Cletus
its HLSD (helical)
easiest way - pedals
and the transaxle code http://forums.maxima.org/showthread....highlight=hlsd
Old Mar 10, 2007 | 09:49 PM
Derrick2k2SE's Avatar
If you have the tranny to inspect you can tell visualy. With the HLSD you'll be able to look through the axle holes and see right through without any obstructions. On the open diff tranny you'll see a round bar crossing on the inside. You can still see through but the bar will be blocking part of the view.
Old Mar 10, 2007 | 10:47 PM
kwk1's Avatar
Originally Posted by soonerfan
its HLSD (helical)
Does this helical lsd use clutches/friction plates?
Or is it like my Torsen and works with worm gears?
Old Mar 11, 2007 | 07:20 AM
http://en.wikipedia.org/wiki/Limited_slip_differential
Old Mar 11, 2007 | 12:11 PM
zenjia 03merlot's Avatar
Im almost positive its the gear driven torsen-type, but instead of regular concentric shaped diff's, is has helical shaped. if you know what a helical shape is, good for you, if you don't: visualize the planetary orbits, earth's orbit aroung the sun. supposedly the helical-shapeness loads up the diff's more smoothly, less noticeble than the first gen lsd w. concentric gears, like Super Handling Preludes, had a tendency of 'oversteering' while cornering and 'overpulling' while doing simple high speed lane switching.
clutches/fiction plates, i believe, are the vicous limited slip diff's [aka vlsd] read that might have some issues with the perfomance, a small lag time in locking the diff's, and long term durability.
all prior suggestions are good, check the VIN number for sure, HLSD have some letter or denotation, check the forums, the answers are there...
love my hlsd, extra comforting while cruising in the snow/icy roads. don't notice it hardly at all in aggressive high/med/low speed turns. or off the line burning.
Old Mar 11, 2007 | 12:51 PM
the Torsens lsds ARE the Helical
otherwise, they are not.
they are supposed to be pretty good at grabbing traction.
TORSEN makes three types, type I are the helical. its their baby...helps the unpredictability of torque steer distribution.
just wanted to know if there was something i could see at the dealer...but I guess it will all mostly be in the shifting/traction. thanks.
Old Mar 11, 2007 | 01:01 PM
the transmission type, on the vin plate on the firewall, will say:
RS6F51H
that is the helical tranny. seems like everyone with that transmission is having problems (sentra spec vs included)?
Old Mar 12, 2007 | 02:12 AM
kwk1's Avatar
Thanks for the link and replies.
I went with a Torsen because the viscous type need to have fluids changed
every couple of years along with the friction plates when they wear out.
It's been 7 years and about 40 dragstrip passes w/slicks and it's still working perfectly.
Old Mar 12, 2007 | 02:28 AM
kwk1's Avatar
Exactly
Old Mar 12, 2007 | 05:24 AM
Viscous lsd uses a silicon fluid in a core, along with a number of discs. The VLSD is speed sensitive as opposed to torque sensitive (with the hlsd).. no clutches involved.
vlsd, depending on your driving style, are supposed to wear out around 60,000miles and require the core be replaced (other wise it functions mostly as an open-diff)
good luck with your purchase
Old Mar 12, 2007 | 09:54 PM
seems that since a lot of the cars for sale are at about 60k, i should make sure its the Torsen tranny. thanks.
Old Mar 13, 2007 | 05:55 AM
just to clarify, it's not a sure thing that it'll go after 60k miles, but it's a known flaw to this type of lsd. You can always check to see if it's still active.
Old Mar 13, 2007 | 02:39 PM
Porkepik's Avatar
Just to be sure, I know I have the HLSD but what does it do exactly, does it mean if 1 of my wheel slip free(like in snow) I will still have one wheel with traction meaning the car is a 2 by 4 not a 1 by 4 like most tractions.
Old Mar 13, 2007 | 07:18 PM
torsen's helical allows smoother shifts and less shock to the actual gears. you have to watch your fluids just like viscous as the design of the teeth allows for more movement/friction and damage to the threading on the outer edge of the gears.
lsd allows perfect power distribution to allow for safer cornering. it is the choice of the sports enthusiast since it allows you to not over corner and hit the guardrail head on (not fun).
also, i just saw what you guys meant about "by the pedals" as the HLSD has the drilled pedals from the factory.
James92SE
142
Jan 2, 2024 09:23 AM
Pied
Sep 26, 2015 03:29 PM
altmycar
Aug 6, 2015 04:44 PM
Amazing2
Sep 27, 2001 02:55 PM
maximaman69
Jul 29, 2001 08:57 PM
