Alignment Question
Old Mar 21, 2007 | 03:49 PM
IloveVQ's Avatar
Alignment Question
Is it really necessary to get an alignment if i am only lowered on eibachs? it doesnt seem like that much of a drop. Also has anyone purchased or used the alignment kit from eibach or one like it to adujust camber? if so how does it work cause it just looks like a bolt with a protruding lobe on it? and alignment can only be adjusted on the fronts right? no need to worry about the rear?
Old Mar 21, 2007 | 04:08 PM
SoonerFan's Avatar
Cletus
you do need an alignment since all the steering parts are in different positions now.
IloveVQ's Avatar
can i use the bolts from eibach or isnt that enough?
Old Mar 21, 2007 | 04:10 PM
SoonerFan's Avatar
Cletus
you need to adjust more than the camber
Old Mar 21, 2007 | 04:15 PM
IloveVQ's Avatar
how much is an alignment from like a local shop?
Old Mar 21, 2007 | 04:17 PM
MAXIMUS86's Avatar
around $60 i would say
Old Mar 21, 2007 | 04:18 PM
IloveVQ's Avatar
cool thanks
SoonerFan's Avatar
Cletus
it varies...go ask around
Old Mar 21, 2007 | 11:09 PM
foodmanry's Avatar
Da Roller Coaster!
Firestone has lifetime alignment for about $150. Definitely a good deal if you are lowdered...I get mine checked about every 6 months.
Old Mar 22, 2007 | 01:50 AM
SilverGLE's Avatar
I'm watching you, boy...
^ +1 I intend to get a lifetime alignment from them once I drop my Max. If you can find it on special, you'll get it for about $100-$125.
Old Mar 22, 2007 | 05:10 AM
JohnWEngle's Avatar
Make sure that you get a 4 wheel alignment. Anything else is a fools errand - a waste of time and money.
Old Mar 22, 2007 | 11:16 AM
IloveVQ's Avatar
How do they adjust the rear wheels?
Old Mar 22, 2007 | 11:20 AM
SoonerFan's Avatar
Cletus
you dont......
Old Mar 22, 2007 | 11:43 AM
IloveVQ's Avatar
Is that guy just misinformed then? (up two)
Old Mar 22, 2007 | 11:47 AM
SoonerFan's Avatar
Cletus
Is that guy just an ediot then? (up two)
i wouldnt call him an idiot....i would say he is misinformed.
you only do the rear wheel with cars with independent rear suspension.
on our cars, they align the fronts with the rear (along with caster, toe, etc)...but the rear cant be adjusted.
Old Mar 22, 2007 | 12:27 PM
JohnWEngle's Avatar
The only thing I'm "misinformed" on is my knowledge of the rear suspension, as I've never personally done an alignment on a Maxima. I wasn't aware that the rear suspension wasn't "adjustable". I don't have a line-up book in front of me. Nonetheless, I'll stand by my advice.
After working in a frame shop, it is very clear to me that ANY car can be adjusted, irreguardless of whether or not the factory offers adjustments. You just have to have the right tools.....
Back into a parking curb really good once and find out how much you can move the rear suspension out of alignment....Then have the local tire & alignment shop tell you the "frame is bent". Our shop got all of the "bent frames" that the local alignment shops couldn't do.
In this case, since you'll not likely take the car to a frame shop to get an alignment done, you'll want to get a thrust alignment. A thrust alignment takes into account the geometry of the rear wheels in relationship to the centerline of the car and then sets the alignment of the front wheels in accordance. Quite often this is billed as a 4-wheel alignment or done in lieu of a genuine 4-wheel alignment.
If you have a 2-wheel alignment done, then the alignment is done based solely upon the centerline of the car for the front wheels only. And this presumes that the rears are in line with the centerline of the car and the frame (unitized chassis) is not genuinely bent/cracked. IF the rear wheels are not square with the centerline of the car and/or there is a bent rear suspension component, the fronts will track properly but the rears will crab one direction or the other. This will cause ill-handling - or from the drivers perspective, constant course correction.
Sorry to have caused confusion over this.
Old Mar 22, 2007 | 02:59 PM
DOHCtorJT's Avatar
Yup, I paid $120 total for mine.
Old Mar 22, 2007 | 03:12 PM
LA02MAX's Avatar
well yeah, you can bend the rear beam to zero out toe (VERY good mod) but there are not very many people that are willing to do that. As for regular maintenence alignments, the fronts are the only wheels you should worry about....
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
doctorpullit
Mar 29, 2016 11:08 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Socalstillen
Sep 26, 2015 12:01 PM
