Got P0140 code need help on current procedure
Old Mar 21, 2007 | 04:23 PM
waltj2k's Avatar
OK So I have a 2000 SE with 116k miles that I just purchased. A couple of days ago I get the SES light. I take it Autozone and they tell me it's a P0140 code identifying sensor 2 bank 1.
I have had a chance to read several posts and I have a general understanding of what I need to do. Change the sensor of course but it also seems that I would need to get the ECU flashed once the sensor is changed out......Is this still correct because I have read about O2 sims as well. I'm a little confused about which procedure I am to do.
Walt
Old Mar 21, 2007 | 04:38 PM
kenshi's Avatar
I don't think you need a reflash with a rear sensor. You could go for a sims for the rears if you want. Do you know if all your sensors are original? If so, expect all of them to go soon.
Old Mar 21, 2007 | 06:14 PM
waltj2k's Avatar
Kenshi,
No I don't know if they are all original. I am going to assume that they are.
No need for a reflash is good news though.
I am also trying to figure out if I want to change the MAF. Now once you change the MAF don't you get a reflash. If so then it would be wise to go ahead and change the sensors and MAF at once then have the reflash. the car seems really sluggish between 2-3k rpm.
Other wise it runs nicely.
Old Mar 22, 2007 | 05:20 PM
kenshi's Avatar
I was mistaken. You should probably get a reflash when you change that sensor. Sorry.
Old Mar 22, 2007 | 05:25 PM
kdaullary's Avatar
you should take it to the dealer and see if your ecm p/n is available for a REPROGRAM to take care of the 140 code. before you just throw a sensor at it
Old Mar 22, 2007 | 05:33 PM
kenshi's Avatar
At a 116k miles, new sensors are probably a good idea.
Old Mar 24, 2007 | 09:03 AM
kdaullary's Avatar
didnt see milage posted. agree on the replacement nissan only covers reprogram till 8/80 anyway.
sctludwig
Sep 1, 2022 01:32 PM
hayne
Oct 5, 2015 11:53 AM
soybeanz
Sep 25, 2015 10:46 AM
maxima297
Sep 24, 2015 10:31 AM
