i got 300z brakes
i got 300z brakes
so i know to put them on the front i need matts bracket but is it the same bracket as the 5th gen relocation or is it different? also what would i have to do for the rear? could i just use the 300z back hub so i could have the e brake or would it not fit thanks alot mike
It depends on what rotor you plan on using. If you are using stock 300zx rotors then you will not need any brackets. If you are upsizing to 6th gen rotors or Cobra rotors, you will need to contact Matt B or Jeff.
Correct me if I'm wrong.
I would get the full setup if I had any money left.
http://www.mattblehm.com/brakes.htm
Hope this helps. http://forums.maxima.org/showthread.php?t=488864
04-16-2020 05:15 AM
06-06-2017 02:01 PM
HerpDerp1919
09-29-2015 02:02 PM
