Squeaky wipers
Old Mar 23, 2007 | 05:07 PM
dafertilizer's Avatar
Squeaky wipers
Ok just replaced some Walmart wipers due to their squeaking, I replaced them with the Bosch ICONs and now they are squeaking???
Read some posts B4 about cleaning the winsheild, so I have tried cleaning it with everything I can think of with no results?
any advice?
Old Mar 23, 2007 | 05:08 PM
SoonerFan's Avatar
Cletus
i have the icons with no problem
they will squeak if you use them on a dry windshield
Old Mar 24, 2007 | 08:22 AM
no it was raining yesterday when I put them on????
Old Mar 24, 2007 | 08:34 AM
CoolMax's Avatar
is invisible
so it was raining when you used them....
try some rain-x on the windshield?
Old Mar 24, 2007 | 12:30 PM
shanki456
Mine do the same thing, and I've replaced them several times
Old Mar 24, 2007 | 01:16 PM
Maxima570's Avatar
You can get the rain-x windsheild washer fluid, but i thought it left a film. I have silicone blades and I'm pretty happy with them, I was looking at the Boschs ones but the silicones are guaranteed for 5 years and I heard the bosch don't last very long
Old Mar 24, 2007 | 01:25 PM
BLUEMAX01SE's Avatar
Try cleaning your windshield with windex or rain x and a razor blade! Go at it at about 20-25 degree angle up and down! It will not damage or scratch your windshield, I have done it a few times with no scratches and damages; had to take off windshield decals before! After that you can apply more Rain X or just clean it with Windex and newspaper! Good luck!
Old Mar 24, 2007 | 01:28 PM
SoonerFan's Avatar
Cletus
use a clay bar
Old Mar 25, 2007 | 01:30 PM
Originally Posted by soonerfan
use a clay bar
where do I get that
BlueMAX, thank, but I have used the razor blade, Windex, Crappy Ammonia based glass cleaner, Im about to pour some gasoline on it and set it on fire
And I thought Rain-ex left a film that would increase your chances of squeaking?
Old Mar 25, 2007 | 01:34 PM
SoonerFan's Avatar
Cletus
http://www.autogeek.net/clbaandlu.ht...FRgYgQodxnj2RA
Old Mar 26, 2007 | 09:18 AM
Hey, just maybe your windshield is so darn clean it's "literally" squeaky clean!
Old Mar 28, 2007 | 10:27 AM
Old Jun 15, 2015 | 07:00 AM
pmalloy90's Avatar
Anybody have thoughts on how to fix this? Just drove 2 hours through the rain, stopped halfway through to buy new blades because the squeaking was driving me crazy. The new blades aren't any better for noise. About to do the 2 hour drive back and dreading it. Wouldn't be surprised if my ears started bleeding.
Old Jun 15, 2015 | 08:30 AM
CMax03's Avatar
Yeah it sound like a dirty windshield to me too and after you clean it clay bar it to ensure all debris is out of the glass pores....Also wipe your wiper blades down with alcohol and if necessary wipe them them down with some 600-1000 grit sandpaper then alcohol to true the blade again...I installed PIAA blades almost 13 yrs ago from Tirerack and they're still going strong with a slight hint or corrosion....
Old Jun 15, 2015 | 09:41 AM
colt149's Avatar
Squeky wiper
I have the same problem before, I tried different wiper, clean the windshield glass and it turn out the main problem is a loose pivot assembly. Lift the wiper arm and try to move the pivot it up and down . If there is a movement , you need to replace it.
http://www.courtesyparts.com/28870-p...957_1996_2022&
Old Jun 15, 2015 | 11:07 AM
Jprocs24's Avatar
I have PIAA blades too, they're expensive but worth it. I can't even get them to squeak on a dry window!
Old Jun 15, 2015 | 02:09 PM
mclasser's Avatar
My driver's side blade ALWAYS squeaks. Doesn't matter if I use el cheapo blades or expensive ones. I've clay bared and cleaned my windshield to no avail. I just live with the noise now. Oddly, it squeaks less in warmer weather.
Old Jun 16, 2015 | 01:33 PM
L_U_D_I_AMaxima's Avatar
I just replaced my wipers after almost 4 years of use... Valeo wipers for life...
stevesmax
Dec 17, 2020 11:57 AM
vingodine
45
May 21, 2016 12:46 PM
leatherneck
Sep 30, 2015 09:16 PM
conansriver
Sep 16, 2015 12:17 PM
