replacing the O2 sensor - where is the wire harness?
Old Mar 24, 2007 | 02:12 PM
Rich96's Avatar
I finally gave in and bought a new O2 sensor the other day. Damn car has had the check engine light on for 100K, but just now started getting bad mileage.
I took a look last time I changed the oil - I can see where the O2 sensor is....but I followed the wire and don't see where it disconnects.
Where does it attach to the wire harness?
Old Mar 24, 2007 | 02:42 PM
SoonerFan's Avatar
Cletus
in front of the engine by the top of the radiator
behind the radiator cap in this pic
Old Mar 24, 2007 | 02:47 PM
kenshi's Avatar
He's got a 3.0 engine.
SoonerFan's Avatar
Cletus
Originally Posted by kenshi
Which sensor? There's 4 on my car. 3 connect in between cylinder bank 2 and the radiator and 1 connects in the between bank 1 and the firewall.
well you probably need to tell us what sensor you are replacing.
you are obviously cali spec
Old Mar 24, 2007 | 02:48 PM
SoonerFan's Avatar
Cletus
i know...doesnt change the location of the O2 sensor wire harness
Old Mar 24, 2007 | 02:52 PM
SoonerFan's Avatar
Cletus
easiest way to figure it out
if you got the sensor from Nissan, the wire cover will be a certain color. match the color of the new sensor to the color of the wires on the car.
Old Mar 24, 2007 | 02:54 PM
kenshi's Avatar
Never mind!
Old Mar 24, 2007 | 02:55 PM
NmexMAX's Avatar
dot dot dot ...
Same holds true for 4th gen harness locations.
Old Mar 24, 2007 | 02:56 PM
SoonerFan's Avatar
Cletus
ive never owned an old @ss 4th gen
but makes sense since its basically the same engine
Old Mar 24, 2007 | 02:57 PM
Rich96's Avatar
I'll have to pull the code to verify, but I believe its bank 1, sensor 2.
So they go from the exhaust all the way up to the radiator? Are they a real pain to route up there?
NmexMAX's Avatar
dot dot dot ...
old @ss 4th gen
SoonerFan's Avatar
Cletus
some people shouldnt work on their cars
Old Mar 24, 2007 | 02:58 PM
SoonerFan's Avatar
Cletus
the routing is a pain in the @ss.
like i said, use the wire cover to determine which sensor you are replacing
Old Mar 24, 2007 | 02:59 PM
Rich96's Avatar
Are you referring to me? Why shouldn't I work on my car?
Old Mar 24, 2007 | 03:13 PM
SoonerFan's Avatar
Cletus
it was a joke
Old Mar 24, 2007 | 03:14 PM
SoonerFan's Avatar
Cletus
locations of all sensors and wire harnesses http://maxima.theowensfamily.com/tsb/NTB02-051a.pdf
Old Mar 26, 2007 | 09:34 AM
CVicVogel's Avatar
I really like how your engine cover has been opened up to release heat. Who did it for you?
thanks!
Old Mar 26, 2007 | 09:54 AM
SoonerFan's Avatar
Cletus
thanks!
a "friend"
Old Mar 27, 2007 | 08:26 AM
d40sithui's Avatar
anyone else getting an eror when loading the link provided by soonerfan? i was able to do it before, nows its screwed up
Old Mar 27, 2007 | 08:32 AM
Ronniels's Avatar
Any idea on the Max if one goes the others are on the way out, so you may as well replace all four? Any opinions?
Old Mar 27, 2007 | 09:15 AM
kenshi's Avatar
If you're not going the sim route, I say replace all four. I did the front two and 3 weeks later a rear went out on me.
Huttig2009
Sep 25, 2015 03:31 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
doobadoo
Aug 15, 2015 06:43 PM
