How many of you went back to stock airbox after WAI?
Old 03-27-2007 | 08:22 PM
n3985's Avatar
大陆弟弟
With my new exhaust drowning out any engine noise, I am thinking of swapping back the stock airbox to regain all the lost torque. Did anyone do this and regret it? I really enjoyed the torque in the low rpms before, passing cars was a tap of throttle, going up hills no problem...etc.
Old 03-27-2007 | 08:35 PM
NmexMAX's Avatar
dot dot dot ...
Increase partial throttle response with this a larger MAF housing and an AFC of some sort.
I hate the wail after a day or 2 using any type of conical filter element.
I now use a stock airbox w/ FC midpipe.
Old 03-27-2007 | 08:39 PM
n3985's Avatar
大陆弟弟
So your intake is:
TB > FC Mid > MAF > stock airbox? I'm guessing a little louder than stock but retains factory like torque?
Old 03-27-2007 | 08:46 PM
NmexMAX's Avatar
dot dot dot ...
Not loud at all. A little more 'fizz', but that's about it.
That MAF housing is holding back the 3.5L. Throttle response was remarkably better.
Throttle lag is gone. Partial throttle response (tsudo torque) is enhanced greatly.
Old 03-27-2007 | 09:09 PM
platinum03SE
my custom intake works great. still have all my torque and some more
Old 03-27-2007 | 09:11 PM
NmexMAX's Avatar
dot dot dot ...
No pics/other info no care.
Old 03-28-2007 | 03:47 AM
Rydicule's Avatar
Don't you know who I am?
Does anyone know how a WAI effects gas mileage? I have a GAB atm, and while I am a bit concerned about loss of low end torque, I have this sneaking suspicion I'm getting better mileage.
Old 03-28-2007 | 03:51 AM
SEmy2K2go's Avatar
Go BUCKS!!!
I've had the Berk WAI on my car for nearly 3 years. I still get over 300 miles per tank...every tank. No loss here.
But in regards to the actual topic, I've removed mine a couple of times for warranty work and didn't really notice too much of a difference.
Old 03-28-2007 | 08:22 AM
platinum03SE
i had some 3 inch exhaust piping laying around. i cut it to fit, had 2 silicon couplers, made a catch can, put on a filter with an adapter. sounds great and rips better then with the stock box. $20 intake > all other
Old 03-28-2007 | 09:14 AM
NmexMAX's Avatar
dot dot dot ...
Stock MAF housing is holding you back at this point.
That coupled w/an AFC of some sort will be most satisfying @ part & full throttle.
Old 03-28-2007 | 09:26 AM
jeff5347's Avatar
I have a warm air filter http://www.cardomain.com/ride/2547814/4
I made it from parts at autozone./ cost me abot $55 to make and it looks clean and more expensdive than it was. It sounds bada$$ and i can def tell it pulls a lot better than stock. I also get over 300 miles to a tank. I had the stock airbox and went to the gab. Off that it sounded good and could feel a difference. Took the gab off and put the WAI on and after the computer relearned the new intake it is a more responsive torqueir (?) engine. I would like t oget some more tubing to make a true CAI and see the diff.
Old 03-28-2007 | 09:31 AM
NmexMAX's Avatar
dot dot dot ...
Butt dyno FTL.
Originally Posted by One Of My Fav Quotes
On the road testing is notoriously inaccurate. You don't feel power so much as you feel change in torque versus time. if the car feels stronger up top, that likely means you are noting a surge or increase in power at a certain point. This is just as easily attributed to making LESS power down low as it would be to making more up top. This is the same sort of "feeling faster" that all of the OBD-II track pipe people experienced. Same peak power, less midrange, and thus the car would have a much larger slope in the power band between the midrange and the high RPM range of operation. This is why the butt dyno should never be used. If you are going to try to make more power by messing with sensors, then do so with proper test procedures in place. A wideband to verify the AFR, as well as a timing light to check for any changes to ignition timing from changed load readings, is really required. The before/after tests should also be done on a dyno with the variables as controlled as possible to verify the change in power.
Old 03-28-2007 | 10:05 AM
jeff5347's Avatar
the butt dyno may not be a true test buty a stop watch is. If you "feel" like the car is quicker than all you would need to do is have already time distance. Once you put on the new acessory you would time that same distance again. If it was in a shorter timespan hp and torque have gone up. HP is not a true measure of power, torque is. Some one stating i make 400 hp and 290 lb ft of torque vs 350 hp and 350 lb ft of torque, you can bet the latter will stomp the 400 hp. Torque is what puts you in your seat. A deisel truck has gobs of torque that can pull stumps.
Ok so after my rambling. Abutt dyno isd not a true test i agree but it can tell you if you are going in ther right direction. I have a 68 camaro that is more tuneable than these cars and the butt dyno is used alot as dyno time is very expensive. So i agree with Nmex dont use the bd as end all be all but it is a usefull tool along with a stop watch .
Old 03-28-2007 | 10:09 AM
MaximumPower01's Avatar
Whats your opinion of the intake shown here, Nmex?
http://www.cardomain.com/ride/410486
Old 03-28-2007 | 10:55 AM
oldskooljdm's Avatar
Nmex, where do you get the larger mass airflow housing?
Old 03-28-2007 | 11:49 AM
wyche89's Avatar
[QUOTE=SEmy2K2go]I've had the Berk WAI on my car for nearly 3 years. I still get over 300 miles per tank...every tank. No loss here.
holy crap are you serious?? i only get a little over 200 miles to the tank.. the gas light usually comes on at about 210-220... i have a 2001 auto with a stillen intake, and i like to drive in the high rpms... should it be that low though? new spark plugs, PCV valve, just cleaned air filter, fresh synthetic oil change, and the gas light was almost on at 219 miles.. put a new MAF on with the stillen intake about 4 months ago.. i reset my tire pressure today, but it was only 2 psi below at the most.. now its at 33 in the front and 30 in the back, so i'll see how this tank goes.. is something wrong with the car?
Old 03-28-2007 | 11:53 AM
jeff5347's Avatar
you should run your tire pressure about 35 lbs all around. My fathers a mechanic and runs this on all the cars that come in. It wont get you 300 mpt but it will help.
Old 03-28-2007 | 12:25 PM
bladerunr's Avatar
high rpm's = low gas mileage
You should see 160 miles per half tank (8 gals) consistently. I do unless I'm on the highway and then its 240 miles per half tank.
Old 03-28-2007 | 12:27 PM
nismopc's Avatar
I did something very similiar to that, but not so "jimmy-rigged" WTF? Down spouts FTL!
Anyhow, I actually lost a lot of low-end torque. If your gonna do a set-up like that, you need to block off the OEM snorkel and just let the lower tubing force air into the airbox.
IMHO, I found it was not worth it and ripped the whole thing out. I am now running a custom WAI and thoroughly enjoy it much more.
I also get over 300 per tank. Usually closer to 350 each fill-up.
Old 03-28-2007 | 12:31 PM
n3985's Avatar
大陆弟弟
MaximumPower, where did you buy your Alessio wheels?
Old 03-28-2007 | 01:58 PM
NmexMAX's Avatar
dot dot dot ...
Where's your PCV breather routed to now?
http://forums.maxima.org/showpost.ph...4&postcount=76
http://forums.maxima.org/showthread....AF#post3852500
http://forums.maxima.org/showthread....AF#post3847561
Old 03-28-2007 | 02:52 PM
nismopc's Avatar
Same location as it was on the stock mid-pipe. Where else would it go?
Old 03-28-2007 | 02:54 PM
NmexMAX's Avatar
dot dot dot ...
I don't see it. Or at least not very clearly.
Old 03-28-2007 | 03:04 PM
nismopc's Avatar
I used an old MAF casing. Cut off the flanged end. Fabricated a custom plate out of a black PVC pipe cap. Cut a rubber gasket out of DIY gasket material. Drilled a hole in the plate. Added a rubber grommet and a 90 degree breather elbow. Attached heater hose to the elbow then fed the hose to the valve cover.
Old 03-28-2007 | 03:06 PM
NmexMAX's Avatar
dot dot dot ...
Gotchya...
Old 03-28-2007 | 03:24 PM
Nice custom set up man!
You in Mansield too, thats cool.....pretty close to me
Old 03-28-2007 | 04:57 PM
NmexMAX's Avatar
dot dot dot ...
I wonder if it increases MAF gm/s.. ..
Old 03-29-2007 | 05:50 AM
Nissanx54's Avatar
very similar to what i will be doing to my car except i am adding a heatshield and running piping to the outside the car to draw in cooler air. btw i get 340 per tank on stock everything in the car as it is now.
JRod28
12-29-2023 09:56 PM
incubusjohnny
11-03-2015 05:18 PM
tcb_02_max
09-11-2015 12:23 PM
sonic7
08-20-2015 12:23 PM
MaximaDrvr
08-19-2015 08:20 PM
Quick Reply: How many of you went back to stock airbox after WAI?
