Clutch Master and Slave
Old Apr 4, 2007 | 05:06 PM
absoundlab
Has anyone changed their clutch master on a 00 maxima? I got the pin out from inside of the car and then I took out the upper 12mm nut and the line going into the master I got that out with a 10mm wrench. How in the world do you take out the lower 12mm bolt? Any ideas suggestions or tips?
Also Im in the process of putting in a fidanza flywheel act stage 2 clutch stainless steel clutch line a new nissan clutch master piolt bearing throw out bearing rear seal and royal purple transmission fluid. Should I go ahead and change the slave? Or just use the original one?
Old Apr 5, 2007 | 06:50 AM
Max_Gator's Avatar
change the slave for sure.
Old Apr 6, 2007 | 04:08 PM
absoundlab
anyone have any advise?
user 11122324
42
Jul 18, 2022 03:35 PM
t6378tp
Sep 29, 2018 04:27 PM
knight_yyz
Nov 1, 2015 01:34 PM
