SE vs GLE suspension
GLE's ride is by no means "garbage". Mine with 60k miles runs like it did when new .. crisp and not floaty. The only change I would make is make it less jumpy over bumps. I don't believe it handles road imperfections very well.
[QUOTE=jeff5347]
I can't comment on the difference between the SE & the GLE suspensions. However, I can comment quite accurately on the difference between 215-55/R17 and 225-50/R17 on the GLE, since I have two '02 GLE's.
First off, the 225-50/R17 is 3% smaller in diameter than the 215-55/R17, so your speedo will indicate a bit higher than you are actually going. It is within acceptable margin of error.
My wife's '02 GLE has the 215's and my '02 GLE has the 225's. Both are Bridgestones - wife has Turanza EL42's, I have RE960AS. Her car has ~56K miles and mine has ~70K miles. Both are stock and identical, except for color and her's has 6th gen brakes. Her car has a slightly softer, smoother, but floatier ride. Mine has a slightly harsher ride than hers and none of the floatiness (if that's a word). And that is driving them back to back. So, I can only attribute the difference in ride quality to the tires. Expansion joints on the freeway are more noticeable in mine. Neither car likes railroad tracks. The RE960AS's are quite confidence inspiring, even in the wet. The turn in is better with the RE960AS's than with the Turanza's (no surprise there.) It would be difficult to comment on braking between the two - her car has better brakes than mine and the brakes on her car are better than the driver has nerve, however, both tires seem to brake more than adequately, with no surprising lock up or skidding in the wet.
Originally Posted by soundmike
Hi Jeff,
I wouldn't say it's bone jarring at all, just slightly rougher than it was with the SE. Also keep in mind i have 245/45/17's on. Some say this helps cushion the ride, although i think it's really transmitting more road imperfections to the car. I also have an RSB and FSTB if that helps you any.
Also the SE i was in had 225/50/17
i have 215/55/17. Im gonna need new tires in a few weeks.
Would the SE tire size make it better. They look wider so handling would be sightly better i think.
yea i thought the different tire size mat\y attribute to a difference in feel. Mine as well hates RR tracks. Smashes them like there are 2x4's for shocks.
The GLE isnt the worst ride ive been in but after seeing what an SE ride is like compared to my GLE, I like the SE so much better. Some ppl are saying they notice no difference and some ppl say the GLE is bad. Maybe my GLE has reached the end of its suspension road and needs new items. Now just need to switch to SE susp or maybe something aftermarket after the wife gets her job straightened out.
Originally Posted by jeff5347
Joeb got his 15. Gotta pop the cherry some how....
Originally Posted by nismopc
Might want to read again. He stated he has "a much more reliable car" than her Passat.
jim
Illjim,
i was reading what you have done to your car. I see progress springs and 18 inch rims. What struts and shocks do ya have. Also i heard the progress springs are a harsh spring. Combine that with the 18.. how is your ride comfort?
as for my ride comfort, it isn't bad when the road is consistent, notice i say consistent. the roads don't have to be perfectly smooth, but as soon as you hit a big expansion joint, pothole or bump, you will know it, no doubt. the 18's shouldn't change things too much, as a matter of fact they didn't, as i had my rims on before i lowered the car. but bigger rims + progress = ouch. there have been many times that i've said sorry to my car after driving. lol.
i've given up on ride comfort on this car now. shocks/struts are getting changed out, polyurethane motor mounts and rstb.........yeah, handling is more fun than comfort.
jim
Maxima/I30 ride...
I have the I30T which is the same as the Maxima SE. I bought the T because of the nicer body spoiler package, much nicer rims and tires, and overall just a more sporty look. It is a pretty rough ride though, and if you go aftermarket with what you are talking about doing, it will be even more rough. Yes, it looks good when the car gets lowered, and we all like a good handling car, but the stock setup with the SE is pretty good. If you try to toy with it, you are going to make the ride even more firm, you will get rattles, bend rims, and they won't last like stock. My I30T has 110k and still rides like brand new. I've talked to dozens that have modified their suspensions and have done so myself on many cars in the past. Unless you are a young guy who prefers style over substance, stick with stock. ESPECIALLY if you have rough roads, all the more reason not to go aftermarket.
I have installed Maxspeed springs and Tokico HP's several thousand miles ago and have not sacrificed any ride quality. What I did gain was a lowered center of gravity, a more aggressive stance, and a smile on my face as I drive 120 miles a day round-trip 5 days a week for work.
By the way, this is my daily family car. I have a 6yr old and a 3 yr old. My wife has no complaints. She actually had no idea I changed the geometry of my suspension until I told her and she "hates" stiff cars.
All I get out of your thread is
which translates to useless knowledge.Great way to start your #1 post on the forum.
Yes, it looks good when the car gets lowered, and we all like a good handling car, but the stock setup with the SE is pretty good. If you try to toy with it, you are going to make the ride even more firm, you will get rattles, bend rims, and they won't last like stock. Unless you are a young guy who prefers style over substance, stick with stock. ESPECIALLY if you have rough roads, all the more reason not to go aftermarket.
if you do suspension correctly, it improves substance. i could care less what it looks like...i did my for improved handling.
why do you think high performance cars have lower stock suspension?? look an an M3 vs other 3 series. anyone who know anything about cars already knows that a car that is lowered correctly will ALWAYS handle better in all circumstances. it lowers the center of gravity and improves handling during cornering.
if you and me where on the highway and had to do an evasive maneuver...i would be able to but your car wouldnt. your car's weight will shift to one side and the car will have huge body roll. when you turn back the other way, all the weight shifts and you have body roll the other way. your car is going to roll over because it isnt planted to the ground.
AaronL
Aug 8, 2020 10:31 AM
Apr 16, 2020 05:15 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Need help
23
Oct 2, 2015 08:56 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
