Took my transmission out and this is what I found
Old Apr 9, 2007 | 10:05 AM
absoundlab
I bought a fidanza light weight aluminum flywheel and an act stage 2 clutch.
While taking out my trans I found that I had a broken rear motor mount. So I bought energy suspension front and rear motor mounts from cattman.
I am also replacing the clutch master slave stainless steel clutch line axle seals and the rear main seal.
Old Apr 9, 2007 | 10:09 AM
absoundlab
The main reason im doing this is because in the morning when I would go to start my car when I push in the clutch and start the car the clutch pedal would stay down on the ground and I would have to let the car sit for about 10 mins before the clutch so to say built up pressure. Also if I got on the car and was shifting fast when I would push in the clutch it would make like a grinding/humming noise. Also if I drove a long distance while driving the clutch would lose all pressure and would fall flat to the floor.
Old Apr 9, 2007 | 10:10 AM
NisMo-Max's Avatar
How much did u buy the fidanza flywheel and from where?
Old Apr 9, 2007 | 10:11 AM
absoundlab
stock flywheel. (what are the heat spots on there from?)
clutch
pressure plate
absoundlab
some of the "fingers" are bent
Old Apr 9, 2007 | 10:13 AM
absoundlab
Old Apr 9, 2007 | 11:44 AM
Tommy Boy's Avatar
Let us know how the Aluminum flywheel works out. When they first appeared people were getting some starter grinding due to problems with poor ring gear engagement, I believe. I curious to see if the problem has really been fixed?!....It's an upgrade I'm interested in doing as well.
Old Apr 10, 2007 | 08:58 AM
absoundlab
well I would love to tell you how it works but I cant get the stock flywheel off I striped one of the 14mm bolts and I have no clue how to get it off
Old Apr 10, 2007 | 09:01 AM
whazzzzuup's Avatar
Originally Posted by absoundlab
well I would love to tell you how it works but I cant get the stock flywheel off I striped one of the 12mm bolts and I have no clue how to get it off
You can get a craftsman extractor from Sears. They will definitely have that size. It looks like a normal socket, excepts it grabs onto strip bolts like yours.
Old Apr 10, 2007 | 09:14 AM
MaxBoost925's Avatar
Drug Money
Not correct for 2000-2001 5-speeds.
Our cars do not have the grinding problem as 5.5 does. I'm pretty much running same setup as asoundlab except for an ACT stage 1 clutch.
Old Apr 10, 2007 | 10:51 AM
Tommy Boy's Avatar
Sorry, my bad, I wasn't looking at the year of his car.
Old Apr 10, 2007 | 11:02 AM
Puppetmaster's Avatar
Fidanza has since been able to rectify the issues. It had something to do with an incorrectly sized ring gear. I think the ring gear was initially too small and had less teeth that it was supposed to. Derrick2k2SE has a Fidanza on his 2002 and was the one who worked with them to get this corrected.
Old Apr 10, 2007 | 12:03 PM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
How are you going to install the motor mounts?? any way someone could check if they are broken without taking it apart?? thanks! sick trunk BTW.
Old Apr 10, 2007 | 12:13 PM
absoundlab
you have to press the old one out and then press in the new one. you can put the car on a lift or jack it up and look at them and see if they are broken.
Old Apr 10, 2007 | 02:48 PM
Theyears02's Avatar
is there a bad ouput shaft seal? im guessing for pass side axle. or is there just oil making it look bad?
Old Apr 10, 2007 | 02:51 PM
absoundlab
ya one of the seals is broken it didnt leak there but I can replacing it
Old Apr 10, 2007 | 02:58 PM
Theyears02's Avatar
thought i saw that. was it broken before or was it a victim of this project?
Old Apr 10, 2007 | 03:08 PM
absoundlab
its not really broken its torn and it was like that before the project.
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
pjgreek
Sep 9, 2015 09:30 PM
