Engine light still on..
Old Apr 9, 2007 | 12:20 PM
Ahmad_1290's Avatar
i searched and still couldnt find anything..
I recently clean my TB and after i started the car the engine SEL came on
so i took it to autozone to get it cleared..so they cleared it, and it came back on about 5 miles later.. so about a week later i found how to reset the ecu
so i did.. then drive about 5 miles and it came right back on
What could it be?
Old Apr 9, 2007 | 12:30 PM
SoonerFan's Avatar
Cletus
What could it be?
instead of just clearing the code...find out what is actually causing the code and fix it so the code doesnt come back.
sounds simple to me
Old Apr 9, 2007 | 01:46 PM
Ahmad_1290's Avatar
the code is p0507 something about high idle ..but it idles at 900
Old Apr 9, 2007 | 02:17 PM
SoonerFan's Avatar
Cletus
after cleaning the TB, you have to do the throttle position sensor learning procedures.
Old Apr 12, 2007 | 10:52 AM
Ahmad_1290's Avatar
is that the same thing as the ECU reset?
Old Apr 12, 2007 | 11:00 AM
SoonerFan's Avatar
Cletus
nope.......
Old Apr 12, 2007 | 11:54 AM
Stardust's Avatar
F---ing Kangaroos
Its unfortunate that you can’t learn common sense in school.
Old Apr 15, 2007 | 11:45 AM
Ahmad_1290's Avatar
well how is the throttle position sensor learning procedure done? on the how to's it takes me right to the ECU reset thing
Old Apr 15, 2007 | 12:02 PM
OC guy's Avatar
2002 maxima se
P0507 - Idle Speed Control System RPM Higher Than Expected.
THIS WILL SOLVE YOUR PROBLEM if not then take to dealer they will only charge around $50 and will perform the relearn procedure.
click the link below read and then click the link that is in second post.
http://forums.maxima.org/showthread....ght=code+p0507
Old Apr 23, 2007 | 05:36 PM
Ahmad_1290's Avatar
ok so after i did the throttle position sensor learning procedures the idle went down to about 600 but then i turn the car off and turn it back on its right back up to 1000. What should i do now?
Old Apr 24, 2007 | 09:25 AM
Ahmad_1290's Avatar
anybody???
Old Apr 24, 2007 | 04:30 PM
kenshi's Avatar
anybody???
Does it stay at 1000 rpm after it's warmed up?
Old Apr 24, 2007 | 05:18 PM
Ahmad_1290's Avatar
yea.. it drops to 900-950 sometimes
Old Jun 6, 2007 | 02:23 PM
Kyle00's Avatar
WSH for teh cup
http://forums.maxima.org/showthread.php?t=500156
I'm new to the maxima scene but it sounds to me that the problem your experiencing is a fried ECU. Follow this link to a great thread on ECU's. It's an expensive fix...... unless your under 80,000 miles then the dealer should cover everything under the Federal Emissions Warrenty. (Of course, thats in a perfect world)
Old Jun 6, 2007 | 02:28 PM
STILLENGLE's Avatar
I dont believe its a fried ECU if that was the case he probably wouldnt be able to start his car Check your MAF.
Old Jun 7, 2007 | 07:33 AM
Maxim(a)SerjVQ's Avatar
Nightmare = Reality
Fried MAF... buy the replacement part and swap it yourself in 5 minutes, or learn about the 2k1 MAF/thermistor change and git'er done yourself in 10 with less out of pocket.
Old Jun 7, 2007 | 07:34 AM
NmexMAX's Avatar
dot dot dot ...
High idle doesn't indicate a fried MAF.
Old Jun 7, 2007 | 10:35 AM
jkayca's Avatar
Sounds like the procedure didn't work. Doing it manually rather than having a nissan tech doing it with the consult II is problematic. Try it again and if you are still seeing problems take the car to the dealer and have them do it.
Old Jun 7, 2007 | 10:42 AM
NmexMAX's Avatar
dot dot dot ...
Apparently he did, see quote below. Seems as his options are limited now:
Let sit for 35+ hours, new/used TB ditto on ECU.
Old Jun 7, 2007 | 11:08 AM
jkayca's Avatar
Yes I saw that but I still recommend trying it again as it sounds like the new settings/parameters weren't saved. Letting the car sit it also a good thing to try.
Old Jun 7, 2007 | 05:39 PM
JiggaD369's Avatar
Happened to me once. While cleaning the TB, did you move the butterfly all the way up or just slightly? Redo the IDLE AIR VOLUME LEARN procedure WITH ECU RESET. If that doesn't take care of it, then let the car sit with the battery disconnected for about 35+ hours just like NmexMAX said above. If that doesn't fix it, let it sit for at least 7 days (did the trick for me after the 2 previous steps didn't take care of it). IF that doesn't fix it, then you know you need a new TB, but that would be my absolute last resort. Try again and again before replacing anything. Good luck!
CorollaULEV
30
Aug 9, 2021 08:11 PM
magneto112
Sep 10, 2015 12:52 AM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
Flores94
Aug 11, 2015 12:53 PM
