Hesitaiton and PowerLoss on High Speed
i am posting this for my friend he doesnt have a maxima.org account. He has a 2001 SE MAX AUTO. PAst few days he noticed somethign strange.
" At certain speeds, like 60-80mph, when I punch the gas, the car downshifts, races up to 4K RPM only to get stuck there. The engine flattens out with absolutely no power and no movement on the tach. It does not feel like it is misfiring at all... just completely neutered."
any ideas?
any ideas?
any ideas?
any ideas?
what SPEED does it get "stuck at"? you said it downshifts...does it then upshift?
no problems in other gears and speeds?
when he tries to accelerate from curising speeds of 60-80mph, he gives it some gas it downshifts and never upshifts again until he slows down enuff to start again.... this only happens at coasting at high speeds. IT accerleartes fine and everything. WHne it downshifts it rises the RPM to 4k and juss stays there and slows the car down, when he gives it more gas it doenst go past 4k.
i had that problem with my 00 auto where it wouldnt always upshift.
anybody else have any suggestions, it has to have happened to someone else.....
Originally Posted by soonerfan
thats a problem related to the tranny (TCM?)
Originally Posted by stocked out max
MAF!!! I had the same problem with my car. I bet he also had trouble first thing in the morning if he doesn't let the car warm up. .
Tell your "friend" its likely an MAF problem (Mass Air Flow Sensor) or TCM (like sooner said)
And there is PLENTY of information on this subject throughout the forum, if you take the time to look through it......
Originally Posted by MaximumPower01
Tell your "friend" its likely an MAF problem (Mass Air Flow Sensor) and he needs to sign up for an account and do some research....
There is PLENTY of information on this subject throughout the forum, if you do the research
why is it holding at 4K RPMs? because its waiting for an upshift
if its the MAF...then why is the tranny not upshifting when it gets to the RPMs its supposed to shift at?
Because my auto tranny did the same exact thing when my MAF went out.......Put in a new MAF, reset the battery for 24 hours, and guess what, no more problems upshifting between 3k and 6k....
sounds like teh maf, tranny wouldnt upshift because your loosing power because of the maf and something is telling the tranny not to shift because of it, when my maf went out my car would accelerate ok till it hit 3.5 to 4k then from there to redline was very flat torque curve as if my car stopped all making any power from 3k to redline.
Ya guys today the car stalled out 5 times on start up, car drives with lack of pressure... Most shosp said its his MAF or his cat.... im thinking its his MAF couz its a known problme on these cars thanks
post whoring to get to 15 posts will get you banned. this is your one warning
i was not post whoring, i was excited that i figured out the problem to his car. and if your going to accuse me of whoring then you should warn 90% of the people on this forum.
James92SE
142
Jan 2, 2024 09:23 AM
Andy29
Sep 29, 2015 05:32 AM
sdotcarter
Sep 2, 2015 09:53 PM
, as is talking through a proxy. After all, getting an .org account is free.
