ATTN: Kev . . .
Old Jul 12, 2001 | 09:46 AM
y2kse's Avatar
Please replace my post in your FAQ-U thread with the following:
Can I run oversized tires on my stock 17" SE Rims?
Apparently not and remain in spec. The most common upsizes for the stock 225/50R17 on Maxima SEs are a 235/45R17 or 245/45R17. Unfortunately, all three Tire and Rim Associations (Japanese, American and European) specify a minimum rim width for these tire sizes of 7.5". The rim width on the stock 5th Gen SE rims is only 7.0".
Many individuals ignore the specifications and upsize anyway. There is a danger inherent in running tires on rims that are too narrow for them, however. Doing so increases lower sidewall stress levels beyond the tires' design limits. In extreme cases, this could lead to sidewall separation.
Although some tire manufacturers state that their 235/45R17 and 245/45R17 tires are spec'd for use on 7.0" wide rims, you should check directly with the manufacturer to make certain that the information is correct and not a misprint before you purchase your tires.
Old Jul 12, 2001 | 11:19 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
What if I don't want to do it? What are you going to do about that?
j/k Updated and thanks for the info.
Old Jul 12, 2001 | 11:29 AM
y2kse's Avatar
Thanks, Kev.
Old Jul 12, 2001 | 12:54 PM
Y2KevSE's Avatar
No problem!
nvmymax2
Jul 12, 2001 11:24 AM
apexi
Jun 30, 2001 09:15 PM
IceY2K1
Jun 7, 2001 04:21 PM
yongjun
May 31, 2001 02:19 PM
Can't Post :)
May 22, 2001 01:12 PM
