Gauge Cluster Failure....
Old May 7, 2007 | 08:36 AM
jeremykedel's Avatar
00 maxima gauges just quit working out of the blue I checked the fuses,when ever I put it into test mode it goes into it but the guages dont work.If I unplug the cluster and plug it back in it works till I drive then it reads 999999 miles on the car and the gauges still work till i turn the car off.Once I turn the car off and back on the odometer is readin like 516k miles on it and the gauges arent working.I am lost I have checked the grounds and fuses.The only thing I havent checked is the wiring at the ecm.I plan on checking it tonight but if anyone has any ideas it would greatly be appreciated.Thanks.
Old May 9, 2007 | 12:06 PM
STILLENGLE's Avatar
you may have a faulty wire. check your battery also. does everything else work fine.
Old May 12, 2007 | 12:51 PM
Yeah everything works fine except the cluster,I checked my codes and have a vss code so i am going to try that first.
Old May 12, 2007 | 04:02 PM
STILLENGLE's Avatar
did you have a sensor decoder i forget what its called you can also try autozone.
Old May 13, 2007 | 07:13 AM
I have a code reader.So I pulled the codes.
Miket2006
Mar 1, 2021 03:55 AM
RWCreative
Sep 21, 2015 11:01 AM
Max139617
Sep 6, 2015 06:02 PM
