HELP!!! bad news from the stealership today..
Old May 26, 2007 | 04:00 PM
@NgRyM@XiM@'s Avatar
I went to the stealership today and learned that I will need to replace my "rear member" among other things. The cost of this including labor is going to be $1,028.00. The mechanic said it's leaking and will start to cause suspension problems soon. I've already noticed the issues as he described them.
Looking at the Max parts list the "rear member" is the same as the rear axle beam, correct? Other parts/services that he suggested are: replacing drive belts ($129.00) and replace or service my emergency brake line because it has siezed on the drivers side.
Help me fellas please! If you know where I can purchase and maybe have these parts install in the Philadelphia area please let me know. Also, if you have had these same issues please let me know your experience and outcome.
Thanks in advance.
Chris
PS: I apologize if this is a repeat issue.
Old May 26, 2007 | 04:55 PM
Squirrel82's Avatar
What kind of fluid does a rear member leak?
Old May 26, 2007 | 05:45 PM
upstatemax's Avatar
Go to a better shop...
It must be slow and they need $$$$.
It was actually grease. I assume this is either from the rear brake line or the suspension (probably the later).
Old May 26, 2007 | 05:47 PM
Agreed! It was Conicelli Nissan in Conshohocken, PA (www.conicelli.com). They charge $96/hour for labor.
Old May 26, 2007 | 09:53 PM
Trurida18's Avatar
wow, 96 bucks an hour...thats steep as hell
Old May 27, 2007 | 07:15 AM
MyBlue02's Avatar
um...the rear member is steal, correct?
how can steal leak?
you most likely need new BUSHINGS, at which point i would look into energy suspensions for as much of them as posible
Old May 27, 2007 | 07:47 AM
Torgus's Avatar
run as far away from them as possible. seriously.
Old May 27, 2007 | 11:16 AM
djfrestyl's Avatar
Suspension Yoda
They probably mean the rear trailing arm, which, IIRC has a bushing that is filled with grease. Since they don't repair and probably don't have just replacement bushings that they can press in, they tell you to replace the entire thing.
Get ES RTA bushings. It will be cheaper and you'll have a better end result.
Old May 27, 2007 | 11:21 AM
irish44j's Avatar
retired moderator
The bushings in the main rear beam, as well as the bushings in the rear trailing arms...both are oil-filled. If they are indeed leaking, you DO need them replaced. Nissan does not sell the inserts seperately, to my knowledge. So you have 3 options:
1. Pay nissan to replace the entire assembly
2. Find an assembly at a junkyard
3. Buy ES poly pieces and install them.
Old May 27, 2007 | 11:58 AM
Gjohnson's Avatar
Like everyone else is saying. Go with number #3.
Old May 27, 2007 | 01:55 PM
Thank you! To everyone who read and shared in this thread, thank you! I've never heard of such before and I certainly don't want to be raped by the dealership.
I probably should replace my struts and shocks while up in there too huh?
Old May 27, 2007 | 01:58 PM
djfrestyl's Avatar
Suspension Yoda
Maximas don't have shocks, they only have struts. They can be a separate job because it's only a matter of one bolt that share the two jobs, and the wheels of course.
BTW, I can do your struts (and springs) when you're ready. See sig.
Old May 27, 2007 | 02:04 PM
Irish, what's the best place to get the bushings? I probably should replace my struts and shocks while up in there too huh?
Old May 27, 2007 | 02:08 PM
djfrestyl's Avatar
Suspension Yoda
Uh, repost? See one post #13.
Old May 27, 2007 | 02:09 PM
Thanks bud, I will take you up on that. Also, I may be interested in the trunk solution too.
Chris
Old May 27, 2007 | 02:10 PM
djfrestyl's Avatar
Suspension Yoda
Chris
Sounds good, let me know.
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
