Climate Cotrl fan squeak - What to do?
Old Jun 5, 2007 | 04:26 PM
rezadue's Avatar
When it is cold outside, my climate control fan squeaks. During the summer months, I don't have any issues.
Is there anything I can do to get rid of this problem?
Old Jun 5, 2007 | 05:47 PM
bwinter7's Avatar
Turn up the radio really loud....... j/k I will benefit from this question as well, because I just write it off as something mildly annoying, but I would like to fix it.
Old Jun 5, 2007 | 06:33 PM
SgtSchulze's Avatar
Burn Dust. Eat my rubber.
It pretty easy to get to if you want to just take it apart and look at it. You may be able to determine the squeak. Just pull out the glove box section etc... and its right behind there. Shouldn't take more than a couple of minutes to get to it.
Old Jun 5, 2007 | 06:39 PM
Saucisse's Avatar
There's nothing you can do about it...too much shaft play in the motor...I replaced mine few weeks ago for the same reason....I pull appart the motor to see if there's was something to be done on it and it's hopeless...to the trash it wents.
Old Jun 6, 2007 | 01:08 AM
rezadue's Avatar
Do you mind if I ask where you got the replacement part and how much it cost?
Old Jun 6, 2007 | 01:30 AM
SEmy2K2go's Avatar
Go BUCKS!!!
http://forums.maxima.org/showthread.php?t=491921
http://forums.maxima.org/showthread.php?t=503078
http://forums.maxima.org/showthread.php?t=497088
http://forums.maxima.org/showthread.php?t=492564
http://forums.maxima.org/showthread.php?t=478665
http://forums.maxima.org/showthread.php?t=433996
http://forums.maxima.org/showthread.php?t=458884
http://forums.maxima.org/showthread.php?t=457257
Old Jun 6, 2007 | 06:13 AM
SoonerFan's Avatar
Cletus
there is a TSB...in the TSB sticky!
Old Jun 6, 2007 | 06:15 AM
Bufflomike's Avatar
Sexier Than Simpson
There were threads whicxh discussed this before?
Old Jun 6, 2007 | 10:22 AM
Saucisse's Avatar
This TSB is no good when the fan is worn out... it was only for the MY 2000-2001 and all 2002 Canadian Maxima came with it standard
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
Miket2006
Mar 1, 2021 03:55 AM
SusieQQ
Sep 9, 2015 12:14 PM
