FSTB or RSTB
Old Jun 6, 2007 | 01:12 PM
maximalxl's Avatar
FSTB or RSTB
I posted this same question on NYC, which would you recommend as first mod............and do I need to get alignment after adding either FSTB or RSTB.........
give your inputs..........thanks...
Old Jun 6, 2007 | 01:13 PM
maximalxl's Avatar
damn i forgot to change my sig......thts my old gle by the way...ill work on the new sig (wit the 02 SE)
Old Jun 6, 2007 | 02:21 PM
SoulEater's Avatar
you need to put both of 'em. if you put either one of them, you only feel a lil' bit differents.
Old Jun 6, 2007 | 03:05 PM
MyBlue02's Avatar
no alignment needed for either
biggest difereance come from hte RSB, its one of hte best mods you can buy.
FST get stillen knock off from FEEBAY
Old Jun 6, 2007 | 09:28 PM
SilverGLE's Avatar
I'm watching you, boy...
^ But he said RSTB, not RSB. I'm sure the RSTB (rear strut tower bar) won't make much of a difference, as I can barely notice the difference with a FSTB. But a RSB (rear sway bar) should make a world of difference from what I've ready...
Old Jun 7, 2007 | 04:33 AM
Rydicule's Avatar
Don't you know who I am?
FSTB
RSTB is a waste of time and unnecessary.
Although, I think the best solution is to buy a good quality rear sway bar, as said above, because those make a noticeable difference, and then spend 10-20 bucks on an ebay FSTB. Cheapest handling upgrade with pretty noticeable differences.
Old Jun 7, 2007 | 05:34 AM
maximalxl's Avatar
hm.....interesting.......so what's a good "RSB"....I will keep away from RSTB.....i have been hearing good things about stillens RSB any other competitors.?
Old Jun 7, 2007 | 05:38 AM
Prophecy99's Avatar
speakin of the ebay knock offs?
is there anything different within the knock offs
meaning are any actually better than another?
or are they all the same? is there a certain one anyone recommends?
Old Jun 7, 2007 | 06:37 AM
MyBlue02's Avatar
ok, you are gonna get flammed by others for asking these questions....try and use the "free search" and you will find tons of info on this.
RSB = Stillen or Progress (get through cattman) they may be others out there but these are the top 2, and unless you really want to be able to "adjust" the RSB (stillen), the progress is cheaper...SEE MY SIG
Old Jun 7, 2007 | 06:38 AM
Maxim(a)SerjVQ's Avatar
Nightmare = Reality
Progress RSB from Cattman. Don't forget some ES bushings for the tail to help the RSB work more effectively.
Old Jun 7, 2007 | 07:01 AM
Prophecy99's Avatar
sorry i meant the FSTB knock offs only,
I wouldnt get knock offs on anything else.
Old Jun 7, 2007 | 07:06 AM
Puppetmaster's Avatar
Neither, because I'd pick a Stage I LTB over the FSTB. But if I had to pick, FSTB. You don't need an alignment after you install it.
There is plenty of good information in the 5th Gen suspension sticky and also more in the Advanced Handling forum.
Old Jun 7, 2007 | 07:10 AM
maximalxl's Avatar
where is the sigg???
Old Jun 7, 2007 | 07:12 AM
http://forums.maxima.org/member.php?u=70310
Old Jun 7, 2007 | 08:04 AM
maximalxl's Avatar
Originally Posted by Puppetmaster
still see no sig??
Old Jun 7, 2007 | 02:45 PM
knight_yyz's Avatar
Toolie
does a stage 1 fit under the headers?
Old Jun 7, 2007 | 03:16 PM
Neither one will fit under Cattman headers. Matt is working on a redesign now, or whenever he has time.
Old Jun 7, 2007 | 04:27 PM
knight_yyz's Avatar
Toolie
ok thanks, I knew the stage 2 would not, wasn't sure about the stage 1
Matt93SE
May 24, 2019 02:58 PM
Ben2003GLE
31
Jul 17, 2016 08:13 AM
maxspeed79
Nov 17, 2000 07:50 AM
F1 Rox
Aug 31, 2000 07:44 PM
