What part is this?
Old Jun 6, 2007 | 05:17 PM
carsarecool's Avatar
What part is this?
On the intake...something to do with the breather system? Can it cause harm or an SES because I took it off?
Its got a bigger hose, and 2 small ones connected to it
Old Jun 6, 2007 | 05:22 PM
bwinter7's Avatar
That's for your vacuum lines ( I think), you probably want to leave that on because you want that air filtered before it is drawn into the engine. If you're putting on an intake, it will have appropriate hook-ups for it, but I would leave it on for now. I wouldnt even want to know what would happen it you got a dry leaf in there or something lol
Old Jun 6, 2007 | 06:16 PM
irish44j's Avatar
retired moderator
Leaving it on will keep your low end around when you get an A/M intake....
Old Jun 6, 2007 | 06:30 PM
I just tried taking it off for sound purposes, I have a WAI if you can even call it that, just a cone filter at the end of that box.
A kid where I worked (autozone) has a cone filter on his 02 saturn SL2 v6, it goes filter right to IM...sounds sick. Really, I'd get a sound clip if I could, its got a real deep growl to it, all my car did was whistle when I put it on, however without this box i have *close* to the same sound so I might put a foam filter on those hoses and keep it off as long as it doesnt throw a code
Old Jun 6, 2007 | 06:31 PM
Bufflomike's Avatar
Sexier Than Simpson
That is because that is the intake resonator. Its job is to reduce the sound of the intake air. Where did you hook your vacuum line to with this removed?
Old Jun 6, 2007 | 06:33 PM
00SEMAX19's Avatar
thats just there to keep noise down, it's a air silencer
Old Jun 6, 2007 | 06:47 PM
I thought it was a resonator. It's still hooked up, just in the engine bay with foam on the ends of it, its not in line with the air filter anymore.
Old Jun 6, 2007 | 07:06 PM
nismopc's Avatar
Huh?
Unbelievable.
Old Jun 6, 2007 | 07:07 PM
NmexMAX's Avatar
dot dot dot ...
It's a Helmholtz type resonator. it.
Old Jun 6, 2007 | 07:08 PM
nismopc's Avatar
At the end of what box? Did you remove the factory airbox and OEM filter or leave it and just put another filter on the end where there is a rectangular opening?
If you've got a dig-cam, please take pics and post. I'd love to see this.
Old Jun 6, 2007 | 07:11 PM
NmexMAX's Avatar
dot dot dot ...
I'm guessing the larger hose if from the VC, 2 smaller ones are from the IACV area?
Originally Posted by nismopc
Huh?
Unbelievable.
Well I haven't driven anywhere far yet, I wanted to see if it made any difference w/out disconnecting any hoses so just put foam filter material on the hole so **** wouldnt get sucked in.
And yes I've heard of Hemholtz resonators before, probably on here I think but thanks for clarifying
Old Jun 6, 2007 | 07:16 PM
Why would I put a filter on the rectangular opening? it's just a crappy WAI I'm sure you've seen one before.. took out the stock airbox and "ram air" and put a filter with an MAF adapter going into the resonator. Now, that was taken out and it goes right to the rubber flex hose into the TB.
Old Jun 7, 2007 | 05:00 AM
Bufflomike's Avatar
Sexier Than Simpson
I am pretty sure you need to have those vacuum lines connected to a working intake so that a vacuum is created to aid in Idle Air Control and EGR recirculation. I believe many have done what you have done but leave the resonator inline.
Old Jun 7, 2007 | 02:23 PM
Yeah I'm probably gonna put it back, the sound increase isnt that drastic
Old Jun 7, 2007 | 02:28 PM
maxspeedse02's Avatar
Thinks he is fast
That is what it's purpose is
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
SpeedCrazie
Sep 16, 2016 03:41 PM
Lowered_a33
Sep 10, 2015 09:41 PM
videomano
Sep 8, 2015 03:28 PM
