For those 5.5 Gens who have Blehmco LTB II installed...help
Hey All,
I purchased the LTB stage II more than a year ago. I never got to install it because when i tried i discovered that the mounting holes did NOT match on the rear mount points.
(they were 3-4mm off) This really discouraged me, ...plus, i knew that my car was still under extended Nissan warranty and any mods could void it.
Anyway....now i am thinking about attempting this install again. The instructions and pictures i have are for 2000-2001 Maxima and it looks like ...the 2002-2003 have DIFFERENT rear mounting points. (i have to use one of the 3 big bolts that hold the control arm).
Does anyone have pictures from a 5.5gen Maxima with LTB II installed? Does anyone have any specific tips/suggestions for installing the LTB II in general? (i am not planning to replace the control arm bushings at this point, even though....my car has close to 100k miles ...i just don't have the tools to press them in/out.)
Any advice on the misaligned mounting points? I really want to have this mod on my car, i spent the money, and i can't afford to fail again. It can't be that hard.
(they were 3-4mm off) This really discouraged me, ...plus, i knew that my car was still under extended Nissan warranty and any mods could void it.Anyway....now i am thinking about attempting this install again. The instructions and pictures i have are for 2000-2001 Maxima and it looks like ...the 2002-2003 have DIFFERENT rear mounting points. (i have to use one of the 3 big bolts that hold the control arm).
Originally Posted by MyBlue02
PM IRISH, I KNOW HE SOLVED THIS OR MAD IT EASIER ON HIS LTB
damn caps from work
damn caps from work
I have the step-by-step instructions for the 5th gen maxima and they all make sense....except that my car looks slightly different under...and that my LTB II does not align properly.
Regardless of model, it will take some hammering with a mallet to bend the front arm(s) to the right position. By hammering I don't mean beat the crap out of it, only hard enough to finesse(sp?) it into shape. It's trial and error.
Second dibs to solve your problem...
Originally Posted by dansmax2003
Hey All,
i have the same issue..i still havent installed it
about an inch or 2 off.... Matt told me that while the specifications are on target, the powercoating process says shrinks the metal to be off so that you have to hit and mold it to fit.
I have tried hitting the crap of out it. It didnt work, but I will not give up. Going to do it soon..Good luck, tell me how you do it if you get it on..
Originally Posted by SilMax00
when you say bushings you mean the front control arm bushings right?
MAXSE5SPD
Sep 17, 2022 04:00 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
imported_Nismo_max
Sep 21, 2015 07:24 PM
ik95
Sep 16, 2015 08:11 PM
