retrofit question!!!
Old Jun 8, 2007 | 04:33 PM
dAAmax's Avatar
i got a pair of ebay projectors, and yes i know that these suck, but not when you retrofit the projector lenses. does anyone know how i can go about doing this...when i open the headlight, how do i put in the new projector lense because its not the same size as the stock one...let me know please, thanks
Old Jun 8, 2007 | 04:45 PM
Mr. Blue Sky's Avatar
when you retrofit those lights you do not retrofit the lense, you retrofit the whole projector. The lights come with H3 projectors(which are crap)
Old Jun 8, 2007 | 07:57 PM
ChromeSE5's Avatar
There is a mounting plate inside the headlight where the projector screws into. When you remove the old projector, you will have to fabricate a way to keep the new projector in. It all depends on what type of projector you are using. I had some MDX projectors and used a nut and bolt system. With my RX330 projectors, I just jd welded them together.
Old Jun 10, 2007 | 10:25 AM
crispykid717's Avatar
Bigger than Jesus
www.hidplanet.com/forums Everything you need to know you can find there.
Old Jun 10, 2007 | 11:26 AM
Teddie18's Avatar
Keep in mind that each retrofit is different based on the model year of your car and the type of projector and ballast you chose to use. Some projectors require cutting the bracket and some don't. Mounting the ballast can be difficult based on the length of the wires, space available and etc.
If you are comfortable working on your car you do it. It just takes time and patience.
Old Jun 10, 2007 | 12:22 PM
n3985's Avatar
大陆弟弟
Easiest route = E46 ECE singles, drops right into bracket w/o modification. Go to Dr. Roy's Cardomain for a DIY.
Old Jun 10, 2007 | 04:45 PM
does anyone know if the new G35 projectors fit into the e-bay housings, and screw in well without too much modification? or should I just go with fx35 projectors??
Old Jun 10, 2007 | 05:04 PM
aw89maxSE's Avatar
The h3's suck. What's Dr. Roy's link? Anymore info on the E46 ECE singles?
Old Jun 11, 2007 | 03:11 PM
SilverGLE's Avatar
I'm watching you, boy...
I've got these headlights and am in the middle of a retro. I can tell you the newer Maxima projectors (E55) will fit, but only if you cut away some of the bracket. I have some E46 Bi-Xenon that I may see if they fit into the bracket without any modification...
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
