Front passenger window slow and not closing all the way?
Old Jul 15, 2001 | 06:31 PM
RussMaxManiac
I noticed for the past months and getting a little worse, the window is taking a while to close, and when it opens, compared to my 2000, the 2001 window does not go all the way into the door, it leaves like 1/8" sticking out on the part near the back of the car on only the front window. I can push it with my hand the rest of the way down. Does anyone else have a problem with this? Any ideas how to fix this? I rather not have to deal with teh dealer if I can just fix it myself somehow. Thanks..
Old Jul 15, 2001 | 06:49 PM
maximadave's Avatar
detailerdaveb@gmail.com
I had the same problem with mine just a month after I bought mine. The Nissan dealership took off my door panel re-adjusted the window track and used this special grease to make the windows go up and down more smoothly.
Old Jul 15, 2001 | 08:33 PM
Wreck-Diver's Avatar
Maybe I should do that also. My 2001 goes all the way up, but it sure takes its time. The 96 Max that I traded had much stronger windows. You could really hear them 'thump' when they hit the top.
Old Jul 15, 2001 | 08:35 PM
spaaz14's Avatar
I've had the same problem since new. The dealer "greases and adjusts" the window. which doesn't do much of diddly squat. Could it be a relay? Whenthe other windows are operated at the same time its even SLOWER, making me suspect maybe its last in an electrical chain. Any one know?
Old Jul 16, 2001 | 05:10 AM
UMD_MaxSE's Avatar
Got Bent?
I think a few people have reported problems with windows going up slow... not a whole lot, but a few.
Old Jul 16, 2001 | 05:18 AM
MaDxKiLLa's Avatar
i have the same problem!
Old Jul 16, 2001 | 05:45 AM
victor's Avatar
i went to the dealer about the slowness and also with my windows i close them all the way up, then a little while after i check to see if they are closed and they still move up a little bit....it's hard to explain. but i saw them for those two problems one, the slowness and two, the window may not be sealing right.
they didn't do jack. they helped the speed problem, but i was more concerned about them sealing right.
to fix the window speed they sprayed silicon lubricant all along the rubber, that lines the window opening on the door. this helped significantly. i was worried about it leaving a oily film on the windows but it doesn't. i bought a can of the stuff at my local auto parts store and use it everyonce in a while, when i detail my car.
Old Jul 16, 2001 | 07:03 AM
y2KAOSMax's Avatar
I'm having a similar problem with my driver side window.. When I put it up or down it screeches. I took it to the dealer twice and they put some lubricant stuff on it that is like a film on the window but after a few days it starts screeeeeching again. So I'm going to take it back again. I think it needs re-adjusted, but hopefully they can get it right this time.....
Old Jul 16, 2001 | 07:56 AM
mike-777's Avatar
Well my 2k SE has been fine in this regard. However my 89 3rd Generation SE windows were slow and didn't close all the way. I discovered that by keeping the inside of the rubber seals ( the vertical ones) clean and siliconed it made a big difference. It is a pain to do, use a lot of paper towels and STP/Armorall. I would do it 2-3 times a year. If you are in a dry dusty area maybe every 2-3 months.
Old Jul 16, 2001 | 05:56 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
My passenger window is slow. Especially when I roll up BOTH front windows at the same time. This makes me think it's a power problem. Not enough "juice" for the motors.
Old Jul 16, 2001 | 06:20 PM
I also have the squeeking windows problem, but only on the drivers side. Seems to do it most when it rains. Maybe I should put some TriFlow on the rail?? The passenger side does not make any noises... probably because it cant get up enough speed to make a squeel.
Old Jul 16, 2001 | 07:31 PM
WILLSE's Avatar
i had this problem but after my windows got tinted it fixed it! i was gonna get something done about it if it didnt get any better glad tinting fixed it!
carguy96
20
Feb 6, 2021 06:21 AM
spidgeon
Aug 24, 2015 11:14 AM
doctorpullit
Aug 20, 2015 05:15 PM
george__
Aug 18, 2015 07:06 PM
follyburr
Aug 7, 2015 09:50 PM
