rod bearing?
Old Jun 12, 2007 | 09:49 AM
Kiosk's Avatar
rod bearing?
I left the Max sitting for a week or so w/o running, when I started up today it made a rattling sound which went away within the second, sounded to me like a rod bearing which quiet down after it got oil
is this thing about to throw a rod on me? I got 130k miles, religiously change oil using synth, and I havent seen any metal shavings in the oil or any of that, car runs great actually
Old Jun 12, 2007 | 09:56 AM
d00df00d's Avatar
Old enuf to pick his own gears
It's probably not a rod bearing. At most it's probably something in the valvetrain that just had all the oil drain off of it and made that sound until it got oil pressure.
If it starts happening after shorter intervals of downtime, you might want to look into it. Otherwise, don't worry about it.
Old Jun 12, 2007 | 10:09 AM
SoonerFan's Avatar
Cletus
im pretty sure the timing chain was rattling due to low oil pressure since the car had been sitting.
Old Jun 12, 2007 | 10:24 AM
Bufflomike's Avatar
Sexier Than Simpson
I agree with sooner...wow that was weird to type.
Old Jun 12, 2007 | 10:25 AM
Kiosk's Avatar
yea I thought valve train first, but it sounded like a deeper rattle than am use to hearing a valve train whcih is more like a ticking noise.....
never heard a timing chain rattle before so have no idea waht it sounds like....
Old Jun 12, 2007 | 11:26 AM
Kiosk's Avatar
should i be looking into replacing timing chain (and gears?)???
Old Jun 12, 2007 | 11:35 AM
d00df00d's Avatar
No, you should be fine. Just keep an eye on it and if it gets worse, then worry about it.
Old Jun 12, 2007 | 12:04 PM
jakesI30's Avatar
In my experience with rod's knocking,,, usually once they start they dont stop,,and progressively get worse,,usually quickly. one easy, quick test is to load the engine while in gear, (power brake) , just a little,, the knocking should increase in intensity if a rod,, but then again,what do I know
Old Jun 12, 2007 | 12:12 PM
SoonerFan's Avatar
Cletus
you should be fine. if anything, you might have to replace the tensioner (there is a TSB)
Old Jun 12, 2007 | 02:27 PM
Kiosk's Avatar
ok, thanks...I was sh1tin a brick for a minute there!!
Old Jun 12, 2007 | 02:56 PM
P. Samson's Avatar
If it was a plain bearing (main crank, big end/small end rod) it would definitely be more of a knock than a rattle and would get worse under load and with the engine warmed up. Nissan considers timing chain rattle for a second or so, normal after a cold start. On a cold start it takes slightly longer for the oil pressure to build than after a hot start. There are three chain tensioners that require oil pressure to do their job, and one lube oil jet which might not spray oil very well right after a cold start because of the cold oil's viscosity. This may be the cause of the noise (rattle) that you are hearing. Some people have (in theory) eliminated this simply by changing oil filters (a less leaky anti-drainback valve can help) and an oil change. Don't panic! Like someone above mentioned, if it was a bearing, it would be a consistant/persistant noise that wouldn't get any better.
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
knight_yyz
Nov 1, 2015 01:34 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
Andy29
Sep 29, 2015 05:32 AM
