Stock vs. GAB - Soundclips
Old Jun 14, 2007 | 06:10 PM
soundmike's Avatar
Very sound, Mike
I thought i'd post this for those curious about how the GAB sounds compared to just the stock airbox.
My audio app doesn't seem to be loading so i haven't managed to clean these up, but you should be able to tell the difference between set-ups. It sounds much better in person both in and outside the car.
Clip specs:
- Recorded 5 feet from the engine bay, off to the driver side
- Rev'd the engine to 4k, 3 times for each set-up
- Hood closed
- The sound is more pronounced early on with each rev as that's the point the throttle is "wide-open"
Stock Set-up
The GAB
Left Channel (Stock) vs. Right Channel (GAB)
Enjoy!
Old Jun 14, 2007 | 07:08 PM
Maxim(a)SerjVQ's Avatar
Nightmare = Reality
i feel like im taking a hearing test.
Old Jun 14, 2007 | 07:55 PM
mist max2000's Avatar
HAHAHA^^^^ it is like a hearing test ,..and i found out that my speakers are messed up on this comp and the right and left's are switched around ha
Old Jun 14, 2007 | 11:40 PM
SilverGLE's Avatar
I'm watching you, boy...
Heh, same here! Honestly, I can barely tell the difference between the 2. But an even better way would be to take a sound clip while driving... That's when the difference was most apparent to me.
Old Jun 15, 2007 | 05:03 AM
nismopc's Avatar
Yes, there is not going to be that much of a difference when sitting still and rev'n the engine. The car has to be under load or WOT to actually hear the difference between stock and modified, WAI, CAI, etc.
Old Jun 15, 2007 | 05:23 AM
SgtSchulze's Avatar
Burn Dust. Eat my rubber.
Also depends on the GAB. Are we talking about the coat hanger or a chopped stock filter holder??
When I tried the hanger, it was definately louder. Then I drilled some holes in my stock filter holder, a little louder than stock but not much. Then I sliced off the entire front half of the holder and it returned to the hanger-style sound. Much louder at WOT.
Old Jun 15, 2007 | 07:02 AM
MyBlue02's Avatar
so does it get anylouder w/ a k&n drop in?
is it even worth the $38 for hte k&n and then worry about popping hte maf?
(i'll prolly never have to clean the filter since i drive a whopping 5,000 miles a year if that)
Old Jun 15, 2007 | 09:05 AM
soundmike's Avatar
Very sound, Mike
Sorry for the hearing test, guys I'll try to take better clips over the weekend.
You can actually hear the difference even w/o the load, since all i did was do a quick sweep from 0-4k rpm, the throttle is only wide at the initial blip - and that's where you hear the difference the most on these clips.
Both set-ups were done w/ a K&N, i didn't hear any difference using the Nissan filter. I've had the K&N for about 20k miles and only got it because i like cleaning it often. There's a lot of construction in our area so the filter gets quite dirty in a short amount of time.
Old Jun 15, 2007 | 09:07 AM
soundmike's Avatar
Very sound, Mike
Originally Posted by SgtSchulze
...Then I sliced off the entire front half of the holder and it returned to the hanger-style sound. Much louder at WOT.
This is what i did, although for the test i drilled two new holes, which seemed to make a difference.
Although, for the record, with the hot and humid weather down here, i felt the loss in low-end pretty easily with the GAB vs. stock.
Old Jun 15, 2007 | 02:17 PM
SilverGLE's Avatar
I've had the GAB using the coathanger and cutting off part of the filter holder (about an inch). Both sound the same to me...
Old Jun 16, 2007 | 08:00 AM
MyownNismo's Avatar
Future Camaro SS owner
I get hearing test every year due to the place I work. I can hear a difference. the GAB has a deeper growl but that's about it.
Old Jun 16, 2007 | 02:31 PM
Nomad's Avatar
You gotta make some under load sound clips. Honestly, it is hard to note any difference by just reving engine. I like my GAB for its mean growl. But, most of all I like to see ppl's faces when they hear it I mean its strange for them to hear such a sound from a daily driver car. It even does attract some G 35's to race me.
Old Mar 30, 2008 | 09:34 AM
hotstartup's Avatar
so to do the GAB all i need to do is dremel some holes into the top of the air box? i read a few threads on it, not clear on directions.
Old Mar 30, 2008 | 10:29 AM
RacerX1320's Avatar
I can tell the difference in sound my hearing is excellent and i guess my speakers are too. Not sure on how to do this mod or if its currently worth it. Ive seen threads go back and forth on this issue. I guess ill just leave it the way it is.
The after sound clip sounds more throaty and better IMO
Old Mar 30, 2008 | 10:57 AM
Kristoefur's Avatar
Maximize
There are a few different variations to do the GAB. Try this for starters before cutting/drilling your OEM box-->http://forums.maxima.org/showthread.php?t=194391
Old Mar 30, 2008 | 11:38 AM
drex1x's Avatar
when i first came to this site the first things i saw was the GAB mod.. i was going to do it .. i looked at videos on youtube and what not .. what i did was went to autozone or autoparts and bought a cone filter.. got the fit for it cut some parts of the tube and hooked it up .. i think it sounds way better and cooler it also gives u a growl when you start going past a X # of rpms.. the only thing now is to get a mid pipe in order to get rid of that 'accordion' looking piece which doesn't let air flow as smooth.. ima try to get some video/audio of it.
Old Mar 30, 2008 | 11:59 AM
jasonmax's Avatar
GAB is more deeper than Stock one.
I'm wondering what's the hearing differences between CAI and stock.
Old Mar 30, 2008 | 12:11 PM
RacerX1320's Avatar
^^^Usually a CAI deletes the airbox completely. Although others will argue what a true CAI is since theyre so many diff styles.
Old Mar 30, 2008 | 10:27 PM
Scottwax's Avatar
That's Mr. Detail to you
Still pretty quiet though, which I like.
Old Mar 31, 2008 | 02:18 AM
hotstartup's Avatar
i dont like the hanger idea for the GAB just does not look or feel right to be. drilling hoes and adding a drier hose might be the way to go
Old Mar 31, 2008 | 09:36 AM
nsnrider's Avatar
I think just by looking at the pics its self explanitory.
There is no good reason to bring back a one year old thred to life for this.
Old Mar 31, 2008 | 01:46 PM
eclipz35's Avatar
short ram intake sounds the best
Old Mar 31, 2008 | 02:47 PM
amomaxima's Avatar
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Oct 25, 2015 02:47 PM
jaydot901
Sep 29, 2015 01:18 PM
Sep 27, 2015 08:37 AM
