5.5 6spd, Throw out bearing going out?
Old Jun 19, 2007 | 09:29 AM
MyBlue02's Avatar
Ok, so i have been getting this anoying Chirping sound when the clutch is all the way out and the car is running, weather its in gear or in nuetral. If i push the clutch in about a 1/2" it goes away completly. Now common sence tells me this is the throw out bearing and it probalby needs to be replaced, however someone told me that it may just be out of adjustment (first i herd of a throw out being adjustable/out of spec).
now there is nothing wrong with my clutch other than the noise and don't realy want to have the tranny pulled just to have the throwout replaced unless it going to score the shaft or damage something (in which case i would just have the cluch replaced while in there since its all apart anyway)
so heres the deal, is my throw out going to destroy anything because its chirping?
is it posible the clutch pedal out of adjustment (needs to be shortened)?
is there there such a thing as an adjustable throw out bearing (or out of spec)?
any clue as to what i am talking about, lol?
i also thought this what contributing the my Clicking sound which i think is my axels (metal clicking sound, almost like the spring fingers on hte clutch pinging like the tines on a cheap black plastic comb and your running your down the tines, only it usually only clicks once or twice) but is still click if i push the clutch in a little and mainly comes from the passanger side.
sorry if it seems like i am babbling, just looking for answers (the chirping is getting anoying, its not very loud but i hear it non the less)
Old Jun 19, 2007 | 09:57 AM
MaximaGT-R's Avatar
I'm a Happy Man!
i dont think its going to destroy anything else it just going to get very annoying, but i might be wrong
Old Jun 19, 2007 | 10:41 AM
oldngivout's Avatar
Willing to learn
On the contrary, if the noise disappears when pushing down on the clutch pedal, which LOADS the release bearing, then it is clearly NOT the problem.
This is the famous input shaft bearing noise. Pushing in the clutch pedal disengages the clutch from the trans and stops the bad bearing from rotating. That is why the noise goes away.
Release bearing may be bad as well, but it will take a trans removal to be certain. You can then rotate the input shaft by itself and diagnose it also.
Old Jun 19, 2007 | 11:06 AM
maximadave's Avatar
detailerdaveb@gmail.com
I have the same problem on my Max. Nissan told me if the noise gets louder then its time to have it replaced, otherwise you won't be able to shift.
Old Jun 19, 2007 | 11:44 AM
MyBlue02's Avatar
even though the pedal is only moving 1/2" and then hte noise slowly comes abck and not not right away?
Old Jun 19, 2007 | 11:53 AM
oldngivout's Avatar
Willing to learn
Is your clutch pedal properly adjusted for free play?
It could be that very little clutch pedal movement is required to disengage the clutch.
Even so, if you are getting a whirring, squealing type of noise from the clutch/trans area, there is a bad bearing of some sort responsible. It will have to come apart eventually to fix it.
And yes, a bad release bearing will soon destroy your clutch fingers.
Old Jun 19, 2007 | 02:51 PM
MyBlue02's Avatar
well i did a little test and the sound does not change with RPM...so what gives?
Old Jun 19, 2007 | 06:04 PM
MyBlue02's Avatar
how much is it to get the spd clutch replaced (avg)
looking to get this chirping situated and taken car of....what have people payed at the dealership to have it done?
i know i know....i really don't want to go to the dealership....but this is something i am not looking to do on my own...from what i unserstand its not a easy thing to do "at home"
from what i gather its the throw out or input shaft bearing mmaking the chirpin from replies to my previos thread, but i wonder why the sound doesnt change with rpms..
any who...how bad is hte price tag?
Old Jun 20, 2007 | 07:38 AM
MyBlue02's Avatar
LOL, i guess my car was still under warenty
so i've been getting this anoying clicking sound and chirping sound from my axels/clutch and just been putting it off sicnce i owned the car and if i had called when i bought the car i would have found out that the car was still under warenty till the end of febuary of this year....talk about a kick to the *****...lol
of well...live and learn...
Old Jun 20, 2007 | 05:26 PM
MyBlue02's Avatar
ok, so its not the throw out of anything internal....it is the slave pin against the clutch fork....there is a slight amount of play and the metal on metal contact get vibrated by the engine running...LOL
so i sprayed it with some white lith and it seems better...
is there a way to put a little more preasure on the fork? worse case is it still makes noise i'll pull the slave and smooth and grease the contact area
Old Jun 20, 2007 | 05:33 PM
ae nissan's Avatar
i have 01 maxima se 20th ae want to swap 6 speed manual tranny in to it but need to know what all have swap parts mount etc
Old Jun 21, 2007 | 04:23 AM
getbigtony's Avatar
what? speak in a complete sentence, not phrases
and way to thread jack
learn to search; there have been numerous 6speed swaps
litch
123
Jan 4, 2024 07:01 PM
maxinout93
Oct 31, 2015 02:04 AM
220k+ A32
25
Oct 3, 2015 09:09 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Andy29
Sep 29, 2015 05:32 AM
