Hood movement at high speeds
At any speeds x>50mph you can see the hood bouncing consistantly, its scary when you think that the thing could fly open. Has anyone expierienced this? And or is there a solution to stiffen the hood so it dosent have so much movement while driving around.
TIA
TIA
When I had my OEM hood, I had the same problem. There is a TSB for it:
http://www.nissanhelp.com/Ownership/.../NTB02-005.htm
Basically, go to the dealership or call up Dave B about the parts. You should get two rubber strips, one for each headlight and a rubber stopper. I didn't do the hood insulator part, but you can do that as well. They definitely helped the vibration on my hood.
There is a TSB for this...can't recall the number, but it essentially gets you some rubber barriers that tape over the headlights and a rubber bumper for the hood. It helped mine a little.
Originally Posted by LACEY DAVIS
There 2 blk ***** on either side just twist them up or down to stop the hood movement
also, weather stripping where the hood meets the headlights helps a lot.
Originally Posted by reeloop
My hood started to do the same thing lately. something is loose I believe. When I first noticed it, I pulled over from the highway because I thought I had left the hood open. Scary stuff
there's a limit to how much you can tweak that rubber stopper, because it won't line up on the sides. . Mine i had to do a balance, because where the stoppers would completely eliminate the bounce, it looked like my hood was popped. . .
I have this issue and wondered for awhile but was too lazy to fix. Maybe I will now. I played with the **** (not mine but the one for the hood
) and that didn't work.
edit TSB is for 01-02? Thats dumb.
) and that didn't work.edit TSB is for 01-02? Thats dumb.
Originally Posted by soonerfan
look at the newbie with the correct answer
Thanks Sooner, i will look into gettin those parts in the TSB.
For now the problem is resolved
lux97Max
Sep 11, 2015 01:12 PM
sdotcarter
Sep 2, 2015 09:53 PM
