Question about tire aspect ratio for SE models
Old Jul 17, 2001 | 06:47 PM
Stealth Interceptor's Avatar
After reading the thread generated by Russ (man! no over there) had me thinking about the issue of speedometer error. I understand that 215/55 16" tires and rims comes STANDARD for all SE models. So, if we opt for comfort and convenient package, which comes with 225/50 17" tires and rims, then we should experience some speedometer error due to aspect ratio/rim size difference, right? (215/55 16" to 225/50 17" ==> 2.16% speedometer error)
y2kse, you point out that going from 225/50 17" to 225/45 17" will produce 3.42% speedometer error (source given by you at http://www.miata.net/garage/tirecalc.html). But shouldn't we rather compare 215/55 16" against 225/45 17"(which actually produced 1.34% error)? what about standard GXE's 15" going to 16" with different stock tire size? which one would you use as a standard reference?
I'm assuming 215/55 16" as a standard reference for all SE models (or maybe for ALL 5th gen maxima models -- and hence produce 0% speedometer error). Maybe Nissan already made special adjustment to this for each model, but I hardly think so...maybe I'm wrong
comments please...
Thanks.
2001 Sterling Mist C&C package
PIAA lights, 33% tinted windows
225/45zr17" Toyo Proxes T1-S
Old Jul 17, 2001 | 06:50 PM
UMD_MaxSE's Avatar
Got Bent?
I think there is a difference in the ECU firmware that is used for 17" wheels vs 16" wheels to correct the speedo error. So, if your car came with 17's use 225/50/17 as the base.
Old Jul 17, 2001 | 06:55 PM
y2kse's Avatar
You are correct, UMD_MaxSE.
Old Jul 17, 2001 | 07:39 PM
RussMaxManiac
To what I was told a while back, that the Maximas with the 17" wheels have a recalibrated Speedo to match correctly. This was by the dealer that told me though....
Old Jul 17, 2001 | 07:48 PM
y2kse's Avatar
That's technically correct, Russ. The recalibration is accomplished by reprogramming the ECM. No changes to the speedometer are required.
Old Jul 18, 2001 | 03:58 AM
wdave's Avatar
I don't buy it for a second. If you calculate the tire sizes and then look at my speedo error with the 16's (about 3%) it becomes suspicious that the 15's are that much taller. I'd guess that the speedo calibration is the same and the tire sizes are chosen to be close in height and load rating.
wdave
Old Jul 18, 2001 | 05:19 AM
bert's Avatar
Just to correct Stealth, not all SE come STANDARD with 215/55R16s, only the Amaerican version. Up here we not only get standard 17's but we also get LSD mmmwwwwwaaaaahhahahhahahahahhahaha! (Oh, Canada! Our home of loaded Maxs.) (FYI up here SEs are always loaded, they a basically a sport version of the GLE, we got the leather, we got the roof, we got the bose) We got screwed on the 20th aniversary skirt kit, but I ain't got no 20th aniversary!
I checked my spedo against a timed run on cruise and the spedo is off by about .5% - 1%
Old Jul 18, 2001 | 07:49 AM
thanks all
Yes, I was actually referring to the U.S. version only, And I know that they are fully loaded in Canada (I used to study in Buffalo and go to Toronto frequently). Unfortunately I have limited budget on my hand which only allow me to go with Comfort & Convenient package (no Bose or leather, but at least I got 17", Sunroof, etc. hehehe!)
I haven't got RSB or STB yet but will get them soon.
Maybe all Canadian Max should be rebadged as GLE-S
2001 SE Sterling Mist C&C
PIAA lights and 33% tinted windows
225/45 Toyo Proxes T1-S
Old Jul 18, 2001 | 11:40 AM
sleepermax's Avatar
plus sizing for 215/55/16's
I'm going to replace my stock Toyos very soon - the sooner the better. But I like and am gonna keep the stock 16" rims. I'm deciding between the Kumho Ecsta 712's or Potenza 730's. I'm leaning towards the Kuhmo's simply because of availability but would prefer the Potenza's. I know that the 16" rims are 6.5" wide so would either 225/50/16's or 225/55/16's fit? Would it even be worth to plus size to these or just keep it at the stock 215/55/16?
MplsMadMan
Sep 4, 2015 02:23 PM
homeyclaus
Sep 3, 2015 06:15 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
gizzsdad
Aug 19, 2015 01:01 PM
xUNIxPanther
Aug 5, 2015 09:31 AM
