Help, Pulled code
Old Jul 6, 2007 | 07:05 PM
machinehead131's Avatar
Help, Pulled code
Today I was on my way to work at the usually 4:40AM and my car decides to throw a check engine light and not rev past 2,300 RPM. Well I thought it could be my oil catch can because I have yet to replace the hose that supposedly melts. I messed with that and it now revs fine and drives fine. I got the code pulled at Advanced Auto and it is P0102 - Mass Air Flow Sensor Circuit Low Input.
I have a VAFC-II and was maybe thinking the wiring could be at fault??? I do not think so but am not sure what circut low input is all about. If my maf was shot or blown wouldn't I not be able to rev past 3k?
Also, When people upgrade to the landrover MAF does it come with the sensor inside or is just the housing? Maybe this is a good time to do the upgrade.
Old Jul 7, 2007 | 12:35 PM
Okay, I replaced the MAF with a 2001 and replaced the transistor. That didn't work. I unplugged my VAFC and reconnected the MAF wires - all wiring is stock now. That didnt work.
The light is still on but the car drives fine, I tried resetting the ECU but that didn't clear it. I went back to advanced auto to get the code pulled and its the same
P0102
HELP!!!!!!!!!!!!
Old Jul 7, 2007 | 01:35 PM
CoolMax's Avatar
is invisible
http://forums.maxima.org/showpost.ph...postcount=2380
Maybe you should post it again.
Old Jul 7, 2007 | 04:56 PM
Originally Posted by CoolMax
Look, I really need help and there was like 10 posts after mine in the Newbies thread. I only have one car and mine shut off on me while I was driving, I lost power steering and eveything. I don't want that to happen again. Telling me what I already know isn't helping.
Old Jul 7, 2007 | 06:35 PM
CoolMax's Avatar
is invisible
At least follow the rules (you're not a newbie)-we aren't at your beck & call.
I'm surprised switching the MAF didn't-did you check the hoses, lines, etc.
http://forums.maxima.org/showthread....16#post4414516
http://forums.maxima.org/showthread....58#post4277458
Old Jul 8, 2007 | 08:39 AM
Ok, I'm gunna try some of that. Any other ideas?
Old Jul 9, 2007 | 12:37 PM
The light is still on, but the car has been driving fine back and forth to work for the past few days. Any ideas?
Old Jul 9, 2007 | 03:04 PM
huffdaddy2008's Avatar
have you tried clearing it? it might just be a stored code now...
Old Jul 9, 2007 | 03:16 PM
SoonerFan's Avatar
Cletus
its a stored code
two options -
1. get the code cleared
2. drive for a few more days. if the problem is fixed, it will go away
Old Jul 10, 2007 | 01:18 AM
Originally Posted by soonerfan
its a stored code
two options -
Another question. If the code is stored, wouldn't resetting the ECU clear it?
I have reset the ECU a few times with no luck.
Old Jul 10, 2007 | 01:38 AM
Correct. Reseting it would clear it. No dice, looks like its not stored. I hope you get it all figured out.
Old Jul 10, 2007 | 01:50 PM
I cleared it today at advanced auto, I dunno why the ECU reset didn't. Maybe I didn't do the ECU reset right. But I am relieved now.
Old Jul 11, 2007 | 08:33 AM
jkayca's Avatar
No. As sooner said it's a stored code. Resetting the ECU will not clear those type of codes.
I went through the same thing when I replaced my MAF. Driving the car for a couple of days cleared the code.
Mar 12, 2020 12:06 AM
hayne
Oct 5, 2015 11:53 AM
