need help with how to regrease windows?
Old Jul 15, 2007 | 11:58 AM
mist max2000's Avatar
my back windows are getting really slow and screeatch really loudly for like 2 seconds when they go up... is there a way to regrease the tracks without pulling everything apart? any help on this would be appreciated...
Old Jul 15, 2007 | 02:26 PM
charr82's Avatar
http://forums.maxima.org/showthread....ghlight=window
Post #9
Old Jul 15, 2007 | 02:36 PM
SoonerFan's Avatar
Cletus
thats a brilliant how to
Old Jul 15, 2007 | 04:11 PM
MacGarnicle's Avatar
I did this this morning... helped a little bit
wasn't aware there was a how-to on spraying silicone in the window jams...or that there was a need for one
Old Jul 16, 2007 | 04:43 AM
bigEL's Avatar
I do this as part of my regular maintenance routine as a preventative measure. No reason you have to wait until you have problems to start doing it.
Old Jul 16, 2007 | 06:06 AM
S.S.Engine's Avatar
I would have taken the door panels off and greased up the track, would last longer.
Old Jul 16, 2007 | 07:11 AM
wyche89's Avatar
Originally Posted by soonerfan
from my cardomain
How to fix problem of windows rolling up slow and squeaking.
RED - Run a wet rag in the window track then spray whole thing with silicon spray.
BLUE - Wipe inside both rubber pieces with wet rag.
soonerfan, is there a reason why we use silicon spray on just the side tracks, and not the bottom?
Old Jul 16, 2007 | 03:14 PM
S.S.Engine's Avatar
To do the bottom track (if there is one) you'd have to take out the door panel. might as well put grease there instead of spraying which would not last as long.
Old Jul 16, 2007 | 03:41 PM
SoonerFan's Avatar
Cletus
that bottom part isnt a track...its just the rubber that the window rubs against. it doesnt cause much friction so it doesnt need to be lubricated. plus, if you did use silicon spray on that, the window would be streaky as hell.
Old Jul 16, 2007 | 09:14 PM
S00NR1's Avatar
OU > *
In addition to soonerfan's how-to, I've had success using rain-x on the interior of the windows (as a supplement to always using them on the exterior).
Old Jul 17, 2007 | 07:39 AM
wyche89's Avatar
got ya... i'll be doing this soon
REDinLV
Aug 15, 2024 12:30 AM
Fbana41
Aug 29, 2016 12:18 PM
Luev
Sep 30, 2015 11:50 PM
