Fuse question
Old Jul 16, 2007 | 07:36 AM
pyroz's Avatar
Fuse question
Is it alright to replace my 15amp foglight fuse with a 20amp? Will that cause any problems at all? I heard it is not good but would like to hear from some experts. Thanks! The reason I ask is because I got HIDs in there and it blew the fuse 2 times already. Thanks
Old Jul 16, 2007 | 07:46 AM
BLUEMAX01SE's Avatar
It's ok to use a 20 amp fuse but you may want to even try a 30amp if you are running HID's! At least your just popping fuses rather than melting the harness! Fuses are much easier to replace!
Old Jul 16, 2007 | 08:03 AM
pyroz's Avatar
My friend told me that putting a 20amp in there is risky because the wire can catch on fire, let alone a 30 amp. Is there any truth in that and how risk y are we talking?
Old Jul 16, 2007 | 10:46 AM
nsnrider's Avatar
don't put a higher rated fuse in a slot that's not desighned for, the 20 amp fuse will not blow(most likely) its just that the wires for the 15 amp fuse slot are disighned to carry a max of 15 amps, overloading them might cause them to melt and short or worse, catch on fire. If you need a higher load, (when adding HIDS) install 20 or 30 amp wires to handle it. Then again, you can risk it and see if anything happens....
Old Jul 16, 2007 | 11:14 AM
maximalxl's Avatar
Old Jul 16, 2007 | 11:50 AM
pyroz's Avatar
alright, thanks guys, i'll go out and get some 15amps and hope they don't blow.
Old Jul 16, 2007 | 02:31 PM
Another question is, are your fuses popping as soon as you turn your fog lights on or do they at least last a while and then melt? If they are popping right away, I would check the connections on the fog light bulbs themselves! Good luck!
Old Jul 16, 2007 | 03:19 PM
S.S.Engine's Avatar
Give more info, how did you wire your HID kit? Is it stock? Did you get a relay kit?
Old Jul 17, 2007 | 04:51 PM
pyroz's Avatar
to answer your questions, the fuse fry once i turn on my hids, i checked my connection, they're all solid and i taped everything up. the first couple of times i turne them on with no problem, then on a cold start when i turn them on, they pop.
the guy cut the power and ground wire going into the stock fogs, then connected the hid's power and ground wire to it. there is no relay involved with the fog hid kit. when i put a 20 amp in there, everything works flawlessly.
any suggestions?
Old Jul 17, 2007 | 06:36 PM
S.S.Engine's Avatar
any suggestions?
I don't suggest that way when wiring the HID. The HID are drawing more power than the suggested amp fuse for the wire. HID require a high current at initial startup and that may be the cause of it. If you can try to find a way to wire the HID without tapping into the existing connections. PM me if you need or want to get harness relay kits. I can refer you to someone.
Old Jul 19, 2007 | 03:41 AM
getbigtony's Avatar
wow i'm not even gonna bother to read responses after the first..
why would u change the fuse? what do you think it's there for? how retarded... the fuse is there to stop excessive current from melting your wires, right? change it, and you let that possibility occur.
get a relay harness man.. doesn't cost that much and you won't have to worry about crap
Old Jul 19, 2007 | 06:51 AM
pyroz's Avatar
just got a relay harness and its all gravy now.
bumpypickle
Sep 20, 2015 08:22 AM
conansriver
Sep 16, 2015 12:17 PM
conansriver
Sep 11, 2015 10:26 AM
jwright36
Sep 8, 2015 11:45 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
