Installing AE manual pedals?
Old Jul 19, 2001 | 11:50 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
What's involved? Are they just covers or do they replace the whole pedal?
Is $53+Shipping a good price?
Old Jul 19, 2001 | 06:07 PM
cfs630's Avatar
I just put all 3 on today. You remove the old pads, then the clutch (if you have one) and brake are just covers that slip over the existing square. The gas pedal is the whole gas pedal assembly unit. It's real easy but you need to make sure you order the whole assembly. I paid $32 bucks for the unit itself. And ?? for the clutch/brake.
Old Jul 19, 2001 | 07:59 PM
IceY2K1's Avatar
The picture showed all three pedals and there isn't an "arm" for the gas pedal. Thanks for the help, I'm going to have to look into it before I order.
Old Jul 20, 2001 | 04:56 AM
dave's Avatar
do you need the whole gas pedal assembly on the 2000 Max, or just the 2001? i thought i read the 2001 gas pedal was different from the 2000. ???
Old Jul 20, 2001 | 08:13 AM
jashick's Avatar
It depends on build date of your car.
Later built 2k's are different than early built ones.
You can check by using a mirror or removing the original plastic gas pedal piece to look at the lever arm. If the end of the lever arm is only in the shape of an "L" then you can just replace pedal only. If the lever arm has an extra metal piece, used to support the plastic pedal when depressed, then you either have to replace the entire gas pedal assembly or hacksaw that metal piece.
If you do a pedal only swap, the new pedal fit is a bit loose so you need to find something to make the arm thicker...either a form of adhesive, tape, or some form of heat shrink to wrap around the metal.
MAXSE5SPD
Sep 17, 2022 04:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
cruce91
Sep 20, 2015 10:23 AM
MaxLife17
Sep 8, 2015 02:36 PM
Johnny9595
Sep 3, 2015 05:18 AM
