Service Engine Soon....P1147 & P0139 Code?
Old Jul 30, 2007 | 05:11 PM
maximalxl's Avatar
Help Guys...........P1147 & P0139 codes showed up when i took it to autozon........i was driving on GSP 1hr ago and the service enginee soon light came on...........soo scared..............AND THE CAR HAS ONLY 45970 EXACT ON THE DOT MILEAGE............PLEASE HELP GUYS................
Old Jul 30, 2007 | 05:15 PM
upstatemax's Avatar
Your bank one secondary o2 sensor kicked the bucket...
Replace it.
Old Jul 30, 2007 | 05:21 PM
NmexMAX's Avatar
dot dot dot ...
Simple as that.
Old Jul 30, 2007 | 05:37 PM
maximalxl's Avatar
can it be under installed under warranty? and would u guys recommend getting it installed by stealership or get it done by TJ or get it from DaveB and install it myself?
Old Jul 30, 2007 | 05:41 PM
pbn85's Avatar
buy the part from Nissan, have your own mechanic install it (of yourself for that matter) and save some money
Old Jul 30, 2007 | 05:44 PM
NmexMAX's Avatar
dot dot dot ...
Buy it from DaveB, which is, essentially Nissan. Try your best to get it done under warranty, but it might more hassle than what it's worth. It's very rare to have Nissan replace O2sensors under warranty.
Old Jul 31, 2007 | 11:11 AM
nk2k2's Avatar
hey man i had the same code. nissan replaced my o2 under the 80k emmissions warrenty. so dont waste your time ordering stuff, when it might already be covered. call your dealer and find out. btw, i had 75k miles when i had it replaced by the dealer.
Old Jul 31, 2007 | 12:48 PM
maximalxl's Avatar
oo cool, thanks alot i was just about to call up Dave B and order it but i saw u left a message...thanks alot again
Old Jul 31, 2007 | 01:43 PM
nk2k2's Avatar
yeah no problem. i did the same thing as you. i ordered the o2 then i come to find out that it was covered. then i had to pay to have it shipped back to daveb. so if your dealer is looking out for their customers, they will gladly cover it. i got my car reporgrammed as well with the new o2. plus your car has almost 50k which will work to your benefit due to lower miles on that perticular year of vehicle.
Old Jul 31, 2007 | 07:06 PM
bigj01AE's Avatar
My bank 2 sensor 2 O2 sensor just went today. The girl at autozone, whom actually seemed to have a decent amount of automotive knowledge in general, mentioned cleaning the 02 by spraying it with compressed air, then starting fluid, then drying with compressed air. Sounds feasible. Anyone ever try this? Also, is there any specific brand of sensor that may be better, or just OEM? Is daveB just someones username on here? Thanks for the input.
Old Jul 31, 2007 | 07:25 PM
NmexMAX's Avatar
dot dot dot ...
Sounds like a band aid. I used to do sorta the same with spark plugs for a non Nissan vehicle. BTW, it's O2, not 02.
Old Jul 31, 2007 | 07:28 PM
SoonerFan's Avatar
Cletus
Originally Posted by soonerfan
both codes are for the same sensor (Bank 1 Sensor 2)...its that one in the precat.
you are correct, you need the white one
1147 - Max Voltage Monitoring
0139 - Circuit Slow Response
http://forums.maxima.org/showthread.php?t=515468
Old Aug 1, 2007 | 05:33 AM
maximalxl's Avatar
droped my car of at Automall 46 and they said to diagnose the problem its $115 if its not under warranty........if its under warranty issue they will do it for free....keepin my fingers crossed that it is a warranty issue.................i kno u said u had it covered under warranty issue but knoing my luck the stealership will be like no its not under warranty so u have to pay...
Old Aug 1, 2007 | 07:51 AM
maximalxl's Avatar
Automall 46 Looked At The Car And They Said For P1147 They Need To Replace Both Sensors And The Price Is $719.00 Wtf !??!??!?!??!?!!?!?!?
Old Aug 1, 2007 | 07:52 AM
maximalxl's Avatar
Dave B Here I Come........
Old Aug 1, 2007 | 07:56 AM
SoonerFan's Avatar
Cletus
you dont need to replace both sensors. just the one i mentioned in the thread i linked.
(Bank 1 Sensor 2)
Old Aug 1, 2007 | 07:57 AM
maximalxl's Avatar
(Bank 1 Sensor 2)
thank you & wut i dont understand is $409 for the labor !? oo and question why does the service bullentin (NTB02-051a) saying on other maximas (excluding 2000) replace BOTH 2 rear 02 sensors..........but anyhow im replace only the white one....thanks bro...
Old Aug 1, 2007 | 08:02 AM
SoonerFan's Avatar
Cletus
labor is expensive cause its a pain to do.
you can replace both if you want...but dave recommended i only do the one. i did it about 8 months ago and havent had a problem.
FYI, it will look like this (the "white" refers to the wire cover not the harness)
Old Aug 1, 2007 | 08:05 AM
maximalxl's Avatar
would u recommend to replace it on my own or have stealership or techniicain install it...
Old Aug 1, 2007 | 08:06 AM
SoonerFan's Avatar
Cletus
you can do it...just takes some time and patience. that one is hard to reach
Old Aug 1, 2007 | 08:10 AM
maximalxl's Avatar
How long did it take for Dave B to get it to u?
Old Aug 1, 2007 | 08:23 AM
maximalxl's Avatar
i just got of the fone with teh stealership exact convo:
me: can you tell me which sensor has gone bad on which bank?
stealer: both rear in both banks.
me: how much is it to replace Sensor 2 Bank 1
stealer: that won't fix the problem.
me: ok, but how much just to replace S2 B1?
stealer: we won't just replace one. you have to replace both
me: so what's teh part number again?
stealer: i dont ask my guys wuts the p/n, i get a problem report from them and i tell u and u give me yes/no
me: ok no
stealer: ok u will have to pay $115 for the diagonise
me: ok w/e leave my car alone
stealer: k thank u
Old Aug 1, 2007 | 08:37 AM
maximalxl's Avatar
Dave B rocks !! $116.00 ship....sucks he didn't have one in stock today but i guess ill wait it out til next tuesday (he says ill get it by them he expcts more on friday)
Old Aug 1, 2007 | 08:45 AM
BigFly_2K2SE's Avatar
I had the same two codes (P1147 and P0139) almost two years ago. I replaced the ONE sensor as per the error code, had the ECU reprogrammed, and have not had a problem since.
The theory that I have read behind the TSB replacing both sensors is that the ECU parameters "could be" causing the problem with the O2s. So the dealership reprograms the ECU and gives you two new sensors rather than replacing just one sensor and having the other one fail later.
The ECU reprogram should be covered to 80K miles. Some have been able to get the O2 sensors covered under this same warranty based on the premise above, however, O2 sensors are typically only covered under the standard warranty. I was not able to get my dealership to cover ANYTHING under the 80K warranty and it was not worth my time to fight with them.
Replacing the O2 sensor is a PITA but it is not difficult. I am not a mechanical wizard by any stretch and I was able to do it. If you buy the sensor from DaveB, it will have all the replacement clips which, IMO, is a very good thing. I found the existing clips to be practically IMPOSSIBLE to remove without breaking them.
Good luck.
Old Aug 1, 2007 | 09:01 AM
maximalxl's Avatar
thanks....i just i wouldn't have gone to stealership to begin with.....now ima have to pay $115 just for them to check out wut was wrong with teh car (diagnosis)
Old Aug 1, 2007 | 09:30 AM
nk2k2's Avatar
hey man you might want to look into this f/s thread. dude is selling oem nissan o2s for 59 shipped.
http://forums.maxima.org/showthread.php?t=529259
Old Aug 1, 2007 | 10:01 AM
maximalxl's Avatar
thanks i saw him, but i figured...i get it from dave b
Old Aug 1, 2007 | 10:50 AM
hokie1525's Avatar
I have a check engine light on after installing a new stereo for an 02 Maxima. Has anyone had this problem?
Old Aug 1, 2007 | 11:59 AM
maximalxl's Avatar
no sorry, i was jus driving and all of sudden it came on.....
Old Aug 1, 2007 | 12:07 PM
nk2k2's Avatar
your joking right?
Old Aug 1, 2007 | 12:36 PM
Bufflomike's Avatar
Sexier Than Simpson
It must be too loud and causing the dreaded knock sensor CEL...lmao
Old Aug 1, 2007 | 02:21 PM
maximalxl's Avatar
Old Aug 6, 2007 | 04:46 AM
maximalxl's Avatar
really weird.....i was waitng for o2 sensor to get to me from daveb but this weekend the SES light went away? and hasn't come back on ever since...............
what do u guys think?
Old Aug 6, 2007 | 05:32 AM
Kyle00's Avatar
WSH for teh cup
I'm not too sure about that as I have the same question myself. My SES light was on for about 4 days for an ignition coil problem but it just turned off and has been off for 2 days
Old Aug 6, 2007 | 05:38 AM
maximalxl's Avatar
LoL
I guess I'll keep the O2 Sensor in the trunk as a backpack incase it does come back on....
Old Aug 6, 2007 | 08:53 PM
LoL
Yes, keep the O2 handy. It will be back, I guarantee it. Might be tomorrow, might be in a week, might be a few months..........but it will return.
Old Aug 7, 2007 | 04:08 AM
maximalxl's Avatar
The Return of the O2 Sensor has been scheduled for a release date of August 07, 2007.
Starting: Maxima lxl - as the main driver
Wordrobe - 2002 Nissan Maxima in Pearl
Director: Nissan
Producer: Mexico
Music By: DJ Maxima
Sorry guys I just had to do that....but yea...the light came back on today morning.....guess tonight will be the day I change it if it doesn't rain here....
Old Sep 14, 2008 | 05:09 PM
devilsalad's Avatar
could someone post DaveB's website??? I cannot seem to find it in the forums..
Old Sep 14, 2008 | 09:43 PM
Scottwax's Avatar
That's Mr. Detail to you
I replaced mine and the SES light came on 160 or so miles later. Removed the code with a code reader and 10,000 miles later, it has yet to reappear.
Sadly, even if you replace it, the light may come on and not go out until you also replace the other O2. However, if you don't replace it, the light is sure to come on again.
Old May 25, 2009 | 06:10 PM
edgar5453's Avatar
Sensor 3 bank 2
Hey Guys sorry, but need to revive this thread. So i'm pulling a P1169 (Not sure exactly what this one means, but i have a feeling it's 02 sensor related) and P0167 (The PCM has determined that a malfunction exists in the heater circuit for oxygen sensor 3 in Bank 2). Looking at the image above i'm still unclear as to which 02 sensor is the one it's refering too? I plan on giving the sensor a clean before actually replacing it if it's reasonable to get too.
