Having Problems With Car Again
Old Aug 8, 2007 | 05:14 AM
STILLENGLE's Avatar
Yesterday I went to the Gas Station and Put $20.00 in i was down to a little under a half of tank so i put in $20 like i said before and that gave 3 Quarters of a tank my brother went to the mall and his friends house which isnt to far from me. maybe 10 miles at the most going to both places. so he gets home and is telling me its back down to a half a tank. and i when and looked at the Gas Gauge and it was reading 1/2 Tank and 167 Miles to go til Empty Now Iam starting to think there is a Fuel Sensor Problem but my car aint throwing any lights on my dash board. Could there also be a small leak in my gas tank.
Old Aug 8, 2007 | 07:39 AM
wyche89's Avatar
i guess a leak is a possibility.. keep an eye out for a leak everytime you park the car, and keep a nose out while you drive for any gasoline smells.. i know sometimes my gas gague reads differently depending on where i am.. like depending on whether your car is tilted a certain way on the road, it can tilt the actual gas in the gas tank, giving it a false reading, but you don't have any less gas in there
i don't know how much that is considered common knowledge, but its the only thing i can think of.. good luck
5.5 gens tell you how many miles you have before you're empty? holy crap, thats hot.. lol
Old Aug 8, 2007 | 07:44 AM
AllMaxxedOut's Avatar
I wish that 4th gens could tell mileage to empty. lol
Well being that you're not throwing codes, that a good thing. I can only suggest keeping an eye out as well for any possible leaks. Usually bad gas mileage would show codes with o2 sensors, etc.
Old Aug 8, 2007 | 07:49 AM
STILLENGLE's Avatar
i might go to the dealer today and see what they say.
Old Aug 8, 2007 | 08:23 AM
maximalxl's Avatar
wut kind of smoke is coming out of exhaust...
Old Aug 8, 2007 | 08:48 AM
SoonerFan's Avatar
Cletus
maybe your brother drove further than he said
Old Aug 8, 2007 | 09:02 AM
maximalxl's Avatar
if he did then give him the
Old Aug 8, 2007 | 09:10 AM
SoonerFan's Avatar
Cletus
well its his twin brother and they share the car
Old Aug 8, 2007 | 09:19 AM
maximalxl's Avatar
wait is it for real or u just gettin me all LoL
Old Aug 8, 2007 | 09:39 AM
SoonerFan's Avatar
Cletus
im for real. he is 17 and shares the car with his twin brother. ive talked to them both.
Old Aug 8, 2007 | 09:44 AM
00MaxSE's Avatar
Pointy Elbows
Keep an eye and a nose out and report back to us.
Old Aug 8, 2007 | 09:47 AM
danger300z's Avatar
so its like kicking himself in the but...lol
Old Aug 8, 2007 | 11:36 AM
maximalxl's Avatar
LoL
Old Aug 8, 2007 | 11:52 AM
STILLENGLE's Avatar
yea you got a good point but he had to be back home at a certain time so he couldnt have gone to far but the mall. i diffenetly gonna check for leaks and stuff.
Old Aug 8, 2007 | 11:56 AM
AceofSpds's Avatar
wat
Lead footed brother possibly?
Old Aug 8, 2007 | 12:07 PM
Bufflomike's Avatar
Sexier Than Simpson
maybe it was really him...with twins you can never tell.
Old Aug 9, 2007 | 05:32 AM
STILLENGLE's Avatar
Ok Last Night When To the Gas Station Filled the Car up t cost 31.00 and some change. my brother went out last night to somewhere but wasnt far. didnt check the gauge i will when my brother gets home from work with it. its 17 miles back and forth to work so hopewfully ill be able to determine the problem. right now iam driving my Moms Benz. so when they get home I am gonna see if the gas gauge droped pretty far.
Old Aug 9, 2007 | 07:37 AM
Rydicule's Avatar
Don't you know who I am?
I've noticed with my car, the gas guage (and the wretchedly inaccurately trip monitor, including the DTE) both drop dramatically whenever I put the hammer down. Make me think I used much more gas than I actually did, as the needles edges upward and the DTE miles increase with some mild driving afterword. As with many other gas mileage threads, I would say measure your actual gas mileage several tanks to see if it really is either horrendously low or constantly decreasing. Then try to determine the problem.
Old Aug 9, 2007 | 07:44 AM
Sunfishsailboat's Avatar
Do you smell a faint wif of gas? If you do look at your fuel injectors. I was told that the 02 Sensor Bank 2 S1 if it wasnot working would run the car rich. Try disconnecting it and see if the code comes up for it.
Old Aug 9, 2007 | 08:55 AM
NmexMAX's Avatar
dot dot dot ...
When will people learn how to take their MPG the correct way? I'm not going to sit here and explain how to do it, because if you can't figure it out, there's not way one can explain with any success. I have yet to see it happen on this site. So, it's either you know how to do it properly or you don't.
Either way, from the past we all know the DTE is not accurate. If anything on these cars, it's very forgiving. It also calculates upon various sensor input, which are all affected by our different driving habits as well as the condition of the car.
I have different injectors and I alter my MAF signal voltage, so the DTE is even more than probably any or most of yours.
So, one item that are fairly accurate is my odometer (give for <1% due to tire wear) and the other is the ever so accurate 5 sig fig fuel pump readout.
Makes sense, and if it doesn't then, well, tell the Nissan dealer we said hi, and hopefully the woman that prints your bill/ticket out is hot.
Also, as per the fuel level sensor. I've never heard of one going out. And I would truly take my advice before I took it to the dealer. Or better yet, check your true MPG, if you know ho, and then you can see if it is indeed a faulty FLS.
Old Aug 9, 2007 | 09:17 AM
Froggmann's Avatar
All of this might also be a diffrence/wear of the resistor on your fuel sender. Both my Max and my Bronco have their needles drop at disproptionate levels. ie My bronco will stay on full for the 1st 75-100 miles drop to 2/3rd at about 70-110 miles hover at 1/2 for about 50 or so miles then make the drop to 1/3 1/4for another 70 miles then make a gradual drop to E from there.
The max has similar patterns, but is diffrent enough to keep me on my toes for now. Your only true estimate of mileage will be from your trip meter and the gal per fill up.
Old Aug 9, 2007 | 11:36 AM
Maxima9750's Avatar
Write down the mileage on it before your brother takes it without telling him. If he puts way more miles on it than he said that he did, beat his a**. You should also reset the MPG gauge to see if he constantly guns it and beats the crap out of the car.
Old Aug 9, 2007 | 11:47 AM
Maxim(a)SerjVQ's Avatar
Nightmare = Reality
this is the only reply you should listen to. trust me, your Bro is sporting around, especially visiting a friend. these cars are practically stealth fighters, in the respect that as I'm sure you well know, they're fun to drive. I would eliminate the user variables first.
Old Aug 9, 2007 | 10:40 PM
Maxima9750's Avatar
Thank you.
I garuntee that your brother is taking the car out for a joyride . All that you have to do is catch him and then do this to him: . He would have to go about 80 miles to burn a 1/4 of a tank, unless he floors it a lot and has fun in big empty parking lots every time he goes out with it. If he's beating the crap out of it, not only is he pissing you off, he is pissing this entire forum off. In that case, we will all gladly come out and him. In the title, you said "having problems with car again", I don't know what other problems you've had, but he may be the reason why you had them. Just my theory, some teens drive like normal people, but there is always those jack-asses that screw around and jack up our insurance rates.
Old Aug 9, 2007 | 10:57 PM
Teufelhunden's Avatar
maybe he was racing? or just flooring it to the mall? showing off with his friend? is he the one who was sipping gas out of the tank or was that someone else?
Old Aug 9, 2007 | 11:22 PM
SoonerFan's Avatar
Cletus
so what if he was flooring it and using gas
im sure they both do that
Old Aug 9, 2007 | 11:40 PM
The Law's Avatar
I R The Law
I have a twin brother.
His name is left foot but he doesn't like the gas pedal. He does love the clutch pedal but my car doesn't have one so he is just resting on the footrest.
Old Aug 9, 2007 | 11:44 PM
SoonerFan's Avatar
Cletus
lack of a clutch FTL
Old Aug 10, 2007 | 12:28 AM
MaxBoost925's Avatar
Drug Money
Pwnt - not wearing his badge FTL.
Old Aug 10, 2007 | 12:37 AM
The Law's Avatar
I R The Law
I just got home *******!
Old Aug 10, 2007 | 08:58 AM
00MaxSE's Avatar
Pointy Elbows
Nice avatars.
Old Aug 10, 2007 | 09:53 AM
lower gas mileage, wasnt that the problem?
Old Aug 13, 2007 | 04:54 AM
SiLvErBaCk82's Avatar
I know that in my brothers SUV he's been filling up and the guage isn't moving at all. The dealer said it is because of the high level of sulfur in the gas (possibly a summer thing). It will eventually reset itself but may cause immediate alarm for a driver. Don't think this is you case but anyways just thought I'd chime in.
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
Samedi
Aug 13, 2015 04:05 PM
erniel
Aug 8, 2015 09:32 AM
yat70458
Aug 3, 2015 01:16 PM
